i need heat for my baby please help - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-22-2010, 08:03 PM Thread Starter
Red face i need heat for my baby please help
Hi guys i posted an add on here yesturday regarding my 03 f350 6 liter would not pump good heat. I was told to change the thermostat and heater core.So my husband did. My engine temp is around 192 but when im on vents and turn my 4x4 on it goes to defrost and blows cold for about 4 minutes then starts to pump the heat again. my automatic hubs dont work when the heat is on vents. My truck blows heat but like i said when i put it into 4x4 and my heat is coming out of my vents is changes to defrost but when i put it back into 2 wheel drive the heat comes out of the vents again. My husband thinks it a vacum leak but he doesnt now where to look. Would anyone have a diagram on the vacum line or what else could it be. please help we are - 40 here today and my baby needs heat so she doesnt get sick. Thanks so much guys
eclipsegt123 is offline
post #2 of 9 Old 11-22-2010, 08:33 PM
ARMY MOM!!!!
korg70kbc's Avatar
Send a message via Yahoo to korg70kbc
u may want to put this in 6.0 problems.....interesting though, mine is doing some similar weird stuff. subscribed............
Laurie
SOLD NCHornet's CCV MOD!, stancor GP relay, zoodad, 6637, fumoto valve, 4" turbo back no cat/muffler, Autometer gauges, & AE avail.
korg70kbc is offline
post #3 of 9 Old 11-22-2010, 08:35 PM
bondsman's Avatar
On the passenger side, on top of the engine is a hose that goes from the near the alternator to the heater core. There is a valve inline that controls how much coolant flows to the heater core. It is vacuum operated and should have a gray line that plugs right in the front of it. It could have come off or the valve could be bad. The valve is near the oil fill tube.
Hope this helps you out...
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
post #4 of 9 Old 11-22-2010, 08:47 PM Thread Starter
that grey hose is on is there. is there a way to bypass this valve
post #5 of 9 Old 11-22-2010, 08:51 PM
bondsman's Avatar
You could remove it and place a section of 5/8 pipe in there to see if it will work.
bondsman is offline
post #6 of 9 Old 11-23-2010, 08:36 AM Thread Starter
so this valve you are talking about has a grey hose going to it right?? where does he put the peice of 5/8 pipe in. will this by pass the vavle all together or will we run into problems down the road. would this valve also stop the automatic hubs from working. I could be sitting still and have my heat on vents and when i turn my nob to put it into 4x4 it goes to defrost. But when i put it back into 2 wheel drive it goes back to vent. My hubs are manual locked and still does the same thing with the heater.
post #7 of 9 Old 11-23-2010, 09:42 AM
bondsman's Avatar
You have a vac leak at the hub. On the pass side, you will see a vac line that goes to the hub make sure they are on both hubs and no cracks. You can follow that line up into the engine comp., disconnect it and plug the end that goes to the truck. Now you wont have esof but hay regain heat
bondsman is offline
post #8 of 9 Old 11-23-2010, 09:46 AM
MUDSTROKIN''s Avatar
I've heard of this problem before, it's def something to do with the vaccum lines for the hubs and whatnot. I'll see if i can dig up an answer for you.
2005 F250 Reg cab LB XL
Airaid CAI
4" MBRP straight pipe from the turbo back.
RCD EGR Delete
Upgraded Banjo Bolts
Zoodad Mod
Swamps HOT FICM
Lariat Captains Chairs with woodgrain center console
MUDSTROKIN' is offline
post #9 of 9 Old 11-23-2010, 09:53 AM
Hopefully this will help you figure out your problems. Take a look here:
Heater quits in 4x4
Airaid CAI
RCD EGR Delete
Zoodad Mod
Swamps HOT FICM
