Purchasing Used SCT X3 units - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-22-2010, 03:20 PM Thread Starter
Switchrider900's Avatar
I understand that the unit has to be unlocked or you have to send if off to SCT and pay the $150.00 fee for them to unlock it.
My question is, if you buy a unit that has custom tunes installed and your truck is not the same strategy, is it easy to remove those tunes from the unit? If so what do you have to do? And if not what can you / have to do to get those tunes removed?
Thx in advance...
Mods:
High Idle Mod
Reverse Back Up Camera
Aftermarket Exhaust
Edge Evolution
Big Rig lights
Zoodad Mod
EGR Delete
Bocar Push Bumper
Levelling Kit
Blue Spring Upgrade
PMM Coolant Bypass kit
Want:
New Steering Wheel
Switchrider900 is offline
post #2 of 2 Old 11-22-2010, 05:37 PM
MoyockPowerstroke's Avatar
Thx in advance...
Once you download the SCT Updater software from SCT's website...you will be able to load new custom tunes on the device...loading the new custom tunes will overwrite the present tunes. . I would Not use the tunes on the device, since you don't know what strategy they were written for...and this may be unwise and unsafe for your tranny. If you can get your hands on an SF3, then you will be able to update the device with SCT's new pre-programmed tunes which are written for strategy VXCF9...this update also give you the ability to turn the EGR valve on/off.
'05 6.0L, 128k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto drain valves, Coolant Filter, ZooDad, HighIdleMod, BullyDog 4" TB, VXCF9 Strat, Edge Insight Gauge, Torque App, Fuel Press Gauge, Upfitters, 4" SJ lift w/Bilstein 5100's, Ride-Rite Airbags, Rough Country Dual Stabilizers, 24" Wipers, '08 Rear Diff cover, Mobil1 Syn 5W-40, 6.4L banjos, Blue Fuel Spring, SS HPOP screen, '08 Mirrors, Zerex ELC.
MoyockPowerstroke is offline
