Banjo bolts - Ford Powerstroke Diesel Forum
Old 11-14-2010, 03:52 PM
Banjo bolts
What Ex actually are the banjo bolts and are they worth replacing on a 2006 6.0?
Old 11-14-2010, 04:07 PM
They are the bolts on the head side of the fuel lines. They have 2 crush washers as well. Just follow the hard fuel lines from the fuel bowl to each head and you will see them.
Basically, the stock banjo bolts have smaller holes and a restrictive check valve. The 6.4l banjo bolts have larger holes and no check valve. The theory behind this is that the updated bolts will allow more fuel to pass which would save your injectors from starving during WOT. It is cheap insurance. About $8 a side.
Old 11-14-2010, 04:33 PM
Banjo bolts
Hey Bondsman what if you already have the upgraded fuel pressure spring? Do you still need the 6.4 banjo bolts?
Old 11-14-2010, 04:35 PM
back to business
I did both at the same time.
Yes, you will still see the benifit from the upgraded banjo bolts.
Old 11-14-2010, 04:38 PM
Just like outlaw said. Do them both. It is inexpensive. I am in the middle of doing head gaskets/studs. I went ahead an bought the spring kit and the banjo bolts. They are both in now. Just waiting on injectors so i can button it up.
Old 11-14-2010, 04:45 PM
anyone around the east texas area wanna help me with the spring and banjo bolt install??? 30 pack budlight included...
Old 11-14-2010, 04:51 PM
Feedback Score: 4 reviews
Anyone have a part number for them?
Old 11-14-2010, 04:54 PM
too bad you werent in connecticut
Banjo bolts
Or a step by step procedure for banjo's. part # also. Mucho appreciated!!!
Old 11-14-2010, 04:55 PM
What is the torque on the new banjo bolts?
