programmer or monitor - Ford Powerstroke Diesel Forum
Old 11-14-2010, 04:40 AM
Hey guys i got an 2006 f350 crew king ranch that i want to leave stock but would like something to monitor everything going on....what do yall suggest was looking at an edge insight but not sure if you can leave stock and just monitor stuff like oil temp and other major items.....new to this so plz help....keep in mind gotta a small billfold!!!!
Old 11-14-2010, 04:55 AM
yes the edge insight will not tune the truck and is just used to monitor. look for a used one on here.
Old 11-14-2010, 05:02 AM
alligator diesel has them on sale for 232.00
Old 11-14-2010, 05:06 AM
edge insight is a great way to do it but i would add a egt probe as well so it can also monitor your exhaust gas temps.
Old 11-14-2010, 05:15 AM
do you know what all it does monitor
Old 11-14-2010, 05:22 AM
the insight cs monitors eot, egt, ect, boost, load, trans temp, voltage, rpms.....it can check for diagnostic codes, and do performance tests like 0-60 and 1/4 times....thats what i can think of off of the top of my head
Old 11-14-2010, 05:29 AM
is there others out there that are good like the edge or are theres the best monitor.....can you adjust tire size and trans shift with this one or is that with actual tuner
Old 11-14-2010, 05:33 AM
tire size yes....and i believe you will need an actual tuner for shift adjustments....i did a lot of research on here and was back and forth between the edge or gauges and everyone that had the edge loved it so i went that route and have absolutely no regrets
Old 11-14-2010, 05:37 AM
so it will adjust speedometer with tire size entry then
Old 11-14-2010, 05:40 AM
yes it will adjust the speed on the actual unit you just need to enter stock tire size and what you have now
