question for the pro's - Ford Powerstroke Diesel Forum
Old 11-10-2010, 01:07 PM
I have a 03 f350 and today when i was under the truck I realized that my down pipe from my turbo was stock and went into a 4 inch pipe. what size is the stock down pipe and if i go with a 4 inch from my turbo back to where the 4 inch meets up will i notice a difrence or not???
Old 11-10-2010, 01:17 PM
Stock dp is 3 inch. Yes you will hear the difference and your engine will thank you for the lower egt.
Old 11-10-2010, 03:32 PM
Chapter Director
isn't it different between 7.3 and 6.0 i thought the 6.0's had 3 1/2 dp and 7.3's had 3" dp. could be wrong just would like to clarify
Old 11-11-2010, 05:09 AM
Slacker
Feedback Score: 4 reviews
Yes, the stock downpipe on the 6.0 is 3.5" and you won't have any noticeable difference by upgrading to the 4" downpipe other than a bunch of dents in your firewall from having to beat the new downpipe in place...
Old 11-11-2010, 05:18 AM
Unapologetically American
That's no chit! Everytime my truck articulates a bit, that engine sounds like its sitting in my glovebox because the DP is hitting the firewall
Old 11-11-2010, 05:23 AM
Slacker
Articulation in a Super Duty?? You make me laugh, sir.
BTW, I didn't notice much (if any) difference when I upgraded my downpipe from the stock (3.5") to the aftermarket downpipe (3.5"). If I had to do it all over again, I might have just gone with the cat-back system.
Old 11-11-2010, 05:26 AM
It twists, a little . It doesn't take much to make that DP kiss the firewall
Old 11-11-2010, 04:18 PM
Chapter Director
Is there much of a egt difference between 3.5 and 4 inch dp?
Old 11-11-2010, 04:21 PM
Not enough to write home about..
And I have a 4" DP, I'll admit it gave me problems but once I got it in just the right spot it has yet to do rub. This has been 2.5yrs now
Old 11-12-2010, 04:28 AM
You don't have any hills in TX to test that out on though, Ben . I should fix mine, because all that weight that's on the DP, is directly added to my turbo
