Replacement down pipe - Ford Powerstroke Diesel Forum
Old 11-05-2010, 06:10 PM
A buddy of mine has a Banks exhaust for a 2005 SD but he don't have the down pipe would I be able to replace the peice.
Thanks
Old 11-06-2010, 03:22 AM
You can call banks and ask but probably not. Good luck in your search.
Old 11-06-2010, 03:54 AM
exhaust is exhaut buy new down pipe and be done with it.
Old 11-09-2010, 06:22 PM
The downpipe end connection may be different. Pull the cat pipe off and look to see what kind of end it has.
I using my stock exhaust as it would be too costly for me to upgrade from 3.5" to 4" or bigger in my cab n chassis frame. I just completed the installation of the MBRP downpipe and cat test pipe. I had to install their downpipe as the end is designed to mate to their cat test pipe. The stock downpipe wouldn't fit up. Their end is flat flange and the stock down pipe is the flared end.
See additional close-up pics of the connection.
Replacement down pipe-dscf1531.jpg   Replacement down pipe-dscf1532.jpg   Replacement down pipe-dscf1489.jpg   Replacement down pipe-dscf1491.jpg   Replacement down pipe-dscf1492.jpg
