Tow question - Ford Powerstroke Diesel Forum
Old 11-04-2010, 01:58 PM
Tow question
Ok guys next week me and my friends are going camping in the mountains in Arkansas. Albert Pike. Its southwest of Little Rock. Anyway I havent really pulled much with my truck. I will be pulling a 20ft lowboy loaded with firewood and 2-3 4wheelers. The bed of my truck will also be loaded. I have an 05 cc with 35's. Im running an SCT livewire and its straight piped. My question is which tune do I need to run? I dont have any custom tunes so it will have to be one of the canned tunes. Also should I run the jake brake setting? BTW there are 2 jake brake settings. What is the difference in the 2?
Thanks John
Old 11-04-2010, 03:10 PM
Chapter Director
do you have gauges? if so then as long as you keep a close eye on temps then you can run what ever tune you want. but if you feel more comfortable then probably be best to run a tow tune. not sure on the 2 jake brake tunes. but i'm sure some one will chime in on it
Old 11-04-2010, 05:59 PM
no i wouldn't suggest running "any" tune you want. cylinder pressure is much more critical than egt or anything else and no shop is selling real time cylinder pressure gauges. egt may melt things, but egt can be fine and still have cyl pressure to lift the heads.
Old 11-05-2010, 12:50 PM
i would run a tow tune not having gauges and you should be ok.
Old 11-05-2010, 12:52 PM
Chapter Director
O well I haven't heard that before I'm sorry I'm still learning diesels but that makes sense
Old 11-05-2010, 03:25 PM
Thanks for the replies. The only gauges I have are what the Livewire shows. I have the EGT probe kit but havent installed it yet. I figured I would probably try the 65 horse tow tune. I am still wondering why it shows 2 Jake Brake settings on there. Also I saw on a different post a guy was talking about the different things he was monitoring with his livewire. One was EOT. Mine doesnt give me that option. Any ideas?
Old 11-06-2010, 05:01 AM
Keep an eye on your trans temp and run a lower setting tow tune. My tow tune from IDP is only 310/560, but that's suggested for towing up to the limit of the truck. With 35s and stock gearing (I'm guessing you still have stock gears), your trans is working a little harder.
Sounds like a good weekend, have fun.
Old 11-06-2010, 06:46 AM
NOT a Democrat
Your tow tune is 15hp less than stock?
Old 11-06-2010, 07:26 AM
Xtreme Street- 420-430rwhp/730-760rwtq- Not recommended for towing.
Street- 400rwhp/670rwtq- Tow up to 10k lbs.
Tow- 310rwhp/560rwtq- Towing over 10k lbs up to the maximum of the truck.
These numbers were taken from an email from Eric @ IDP.
All the tunes listed are measured at the rear wheels. I don't remember if the stock measurements are based at the flywheel or rear wheels, but I doubt that a stock truck puts 325 hp on the dyno rollers.
Old 11-06-2010, 02:12 PM
Im really not sure about the gearing on my truck. I havent done anything to it, but I dont if the previous owner may have changed them out. I had to make a trip out to Dallas this morn. Driving on the interstate at 70mph I am turning right at 2000rpm's.
