High idle mod - Ford Powerstroke Diesel Forum
Old 10-28-2010, 04:55 PM
High idle mod
I have a 2006 f250 and located the White/Blue and the Orange wire under dash. I added extension wire to each, started truck, applied E brake, and touched two wires together to test and didn't get any results. There were two wires near E brake that seemed to resemble Orange wire, I tried both with no results. Any help would be appreciated
Old 10-28-2010, 09:43 PM
Do you have factory Upfitter Switches ? If so ... locate the BCP wire ( Battery Charge Protect ) Purple wire with light green tracer/stripe located in a bundle near top of parking brake assy. Connect to Aux 3 or 4 switch. Aux 3 is a Orange wire yellow tracer/stripe and Aux 4 is a Orange wire light blue tracer/stripe. The Aux 3 & 4 wires will be in a small bundle near top of fuse panel ... all Orange with different color tracer/stripes. If using the High Idle Mod for PTO applications ... locate the SEIC wire ( Stationary Elevated Idle Control ) solid Orange wire in same bundle as Purple wire and connect to Aux switch instead of Purple wire. The main difference is the SEIC circuit will lock the torque converter and the BCP circuit won't. The color wires you were referring to are for a 2005 application and will not work. Hope this helps.
Old 10-29-2010, 06:32 AM
Which color wires would be connected to swithc to do a high idle on 05?
Old 10-29-2010, 08:33 AM
Hey BIGEBLU pm sent
Old 10-29-2010, 08:39 AM
Check 6.0 tech files/ mod help. I believe post was on a 2005. Orange near e brake and white/blue near OBD port
Old 10-29-2010, 07:10 PM
blackshadow ... pm sent
Old 10-30-2010, 07:27 PM
