6.0L Question/Problem - Ford Powerstroke Diesel Forum
Old 10-25-2010, 05:33 PM
So, for this winters project will be in the motor... Here are the plans...
ARP Head Studs,
Sinister EGR Delete
Heads Decked
Black Onyx Gaskets
New Oil Cooler
Coolant Filter Kit
What else should I do?
Also, little problem came up this week. Truck started to leak alot of oil. Seems to be coming from above the trans on back side of motor. My guess is turbo. But I wanted to hear others opinion and what else I should look for when I start tearing into the truck.
Thanks guys,
Pigg
Old 10-25-2010, 05:52 PM
Feedback Score: 3 reviews
I see your truck is an '04. If it's an early '04, then your oil leak might be the ICP.
Old 10-25-2010, 05:59 PM
Yes. I believe its an early 04. Motor I think has 03 build date on sticker on passenger valve cover. Whats ICP? Im not good with these abbreviations.
Old 10-25-2010, 06:04 PM
Injector control pressure sensor.
Old 10-25-2010, 06:05 PM
ICP- Injection Control Pressure sensor.
Old 10-25-2010, 06:06 PM
So, That would leak? I didn't know if it was seals? or maybe the drain tube.. seen alot of people upgrading those.
Old 10-25-2010, 06:17 PM
They do tend to go bad and sometimes leak. Much easier to get to from the bottom too, especially on a lifted truck.
Old 10-26-2010, 05:30 AM
Some 190's from Casserly and a Powermax to go with them.
Old 10-26-2010, 06:08 AM
HAHA.. I wish I had to extra money. That would wake her up a bit Im sure.
Thinking about throwing new glow plugs why Im in there. Gonna have a buddy clean my turbo while its out.
Old 10-26-2010, 06:13 AM
Flush the engine good and switch it to a Cat EC-1 rated ELC coolant (red). Get that Ford Gold crap out of there if you haven't already.
