How much PSI can the stock I/C take - Ford Powerstroke Diesel Forum
Old 10-22-2010, 04:58 AM
Feedback Score: 10 reviews
I heard that the plastic end tanks on the innerccooler will blow out after 40 PSI??? Is that true???
Old 10-22-2010, 05:04 AM
I would say that that is a pretty fair estimate although I've seen/heard of them blowing out at lower boost pressures. Mine has seen 40 or so more than once with no issues, but (knock on wood) I consider myself lucky. Depending on what you're doing with your truck you should probably look at something aftermarket like the Banks Technicooler.
Old 10-22-2010, 05:33 AM
I was just thinking about a 2000 7.3 all aluminum? You can pick those up prety cheap. DO you think that will fit in the stock location?
Old 10-22-2010, 03:42 PM
That would be like going backwards. They don't flow or cool as well
Old 10-23-2010, 02:17 PM
mishmoto looks good decent price to
Old 10-23-2010, 06:27 PM
is there any information to back that up? I wouldnt think there would be that much difference.
Old 10-23-2010, 06:39 PM
People swap the 6.0 intercooler in place of the 7.3 one because it is taller and for some people has dropped EGTs 100+ degrees.
Old 10-23-2010, 06:52 PM
ok there goes that idea
Old 10-23-2010, 06:57 PM
Now if it was a full on, single purpose truck, like for racing/sled pulling, then it would work, but for a driver, it'd just be
