HELP!!! Serious issue I think - Ford Powerstroke Diesel Forum
Old 10-21-2010, 02:21 PM
So Im in the process of putting headstuds in my 6.0 i had the head sent out and deck and they had to take .012 off the the heads to get them straight. IIRC the most that can come off is .010. Any idea on what I can do to fix this without buying new head?
Old 10-22-2010, 03:44 AM
IIRC the max take off is .008. You're looking at a new head.
Old 10-22-2010, 05:06 AM
SVT is absolutely correct. You're looking at piston/valve interference issues if you run with .012 cut heads.
Old 10-22-2010, 06:06 AM
I just read on here about another guy who had his decked .015, recessed the valves .020, and used 7.3 injector washers said it worked perfect
Old 10-22-2010, 08:53 AM
FML nobody make an thicker gasket or anything like that?
Old 10-22-2010, 11:16 AM
Is the black onyx gaskets thinker then the oem ford ones. The guy at the machine shop said the oem gaskets are .045 and the black onyx gaskets are .080. Does anybody have have acess to them to mic them or atleast mic the oem ones I have the black onyx ones and i can mic them myself?
