What is the max boost an 03 turbo will make on a 6.0?? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-17-2010, 10:22 PM Thread Starter
Send a message via AIM to Chaz Byrge
Question What is the max boost an 03 turbo will make on a 6.0??
I have head studs, gaskets and an o ring kit installed on my motor so I dont have to worry about blowing the top end, I just need to known how much boost the stock turbo will make? can any body help me with this?? THANKS!!!
Chaz Byrge
Chaz Byrge is offline
post #2 of 9 Old 10-17-2010, 10:26 PM
metstroke06's Avatar
With a hot race tune like custom extreme race from ID you will see boost probably between 30-33psi. Thats what I saw.
2006 F250 King Ranch
metstroke06 is offline
post #3 of 9 Old 10-18-2010, 04:08 AM
Location: Greencastle, PA/ Marine Barracks Washington D. C.
Read before posting.... I have a tread out there already about this.... I saw 40 PSI with a stock turbo. If you have any other questions refer to that tread you will see your answers
2003 F-250 6.0
-6spd 4X4
-aFe Stage 2 intake
-aFe intake manifold
-Zoodad
-4" MBRP turbo back duals 6X24 tips
-ARP head studs
-Custom tuned SCT
-EGR cooler upgrade
-Oil cooler upgrade
-Custom removed blow by pipe
-2.5 leveling kit
StrokenUSMC03 is offline
post #4 of 9 Old 10-18-2010, 04:13 AM
f250ghost's Avatar
I saw 37psi on mine when the boost line to the gauge popped off.
-Ben
2011 F250 FX4
6.7 PowerStroke
f250ghost is offline
post #5 of 9 Old 10-18-2010, 08:40 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Never seen more than 31 with mine.
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 9 Old 10-18-2010, 10:27 AM
Really? I was seeing 35psi with Xrace.
06 F350 Traded
alwil is offline
post #7 of 9 Old 10-18-2010, 06:41 PM
back in the saddle
shu873's Avatar
The 03 trucks seem to see a little more peak boost than the newer models.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #8 of 9 Old 10-20-2010, 05:16 AM
03-04 turbos have approx 3/10" bigger inlet right before the compressor than the 05-07. I have a standard trans as well that may have assisted to. Zoodad and aFe intake manifold were done after I say the 40PSI on an Isspro gauge. IDK if the PCM can/will read more than 32
2003 F-250 6.0
-6spd 4X4
-aFe Stage 2 intake
-Zoodad
-ARP head studs
-Custom tuned SCT
-EGR cooler upgrade
-Oil cooler upgrade
-2.5 leveling kit
post #9 of 9 Old 10-20-2010, 06:52 AM
PGreenSVT's Avatar
I have an 03 turbo running on my 05. I am running Matt's SRL+ for studded motors. Best I see is 31. Maybe it'll be more when the temps drop into the frosty zone.
RIP Mitch
the Org crew
