Newby here looking for mod opinions
Hello, I'm new to this site and diesel trucks and would like some suggestions for where to start on mods since I'm in need of deleting my EGR cooler and will need a SCT custom tune to by-pass the CEL once doing this.
I bought a 2005 F250 FX4 CC 6.0L with 115K miles and after the fact noticed coolant level keeps droping and no sign of where it's going other than a steamy exhaust. I had intended to drive the truck stock for awhile before putting much $$$ into it to make sure it would work out for my needs but I need to correct this problem now and I think I am liking the truck well enough to keep it for several years, it sure handled the 10K lb load I pulled today very well, this is my first 3/4 ton truck. I'm planning on doing the EGR delete, upgraded oil cooler, STC fitting, dummy plugs, upgraded trubo drain tube and clean the turbo myself for now, wanted to do the head studs but currently don't have the facilities and time to tackle that job right now so one question is what is the odds of me having head gasket troubles by putting a tune on the truck even though I am a fairly light footed driver? I'd like a bit more bottom and mid range torque to get the truck moving a little freeer but I'm not looking to race it or dog it. First I'm looking relability, second a MPG increase and then to free up a few ponies. After doing the things listed above what would be a good next easy step? Exhaust, intake? I'm sure I probably need to install an EGT gauge, is there a stock sensor that can be monitored for this or do you have to drill and tap for a new sensor? Sorry guys for the long post, again I'm new to this 6.0 creature but I have been reading up alot on it and I'd like to hear some of your opinions on upgrades you think would best suit me for the way I'd use the truck which is occasional heavy towing and looking for reliability and better economy but not trying to make a race truck. Thanks |
3-Gauge Install Pictures I like the Edge Insight with pyro and dash pod Get a fuel pressure gauge and the adapter 6.0L Fuel Pressure Adapter Install Pictures any thing under 45 lbs at WOT kills injectors Hope this helps 2 stroker |
DO NOT TOW UNTIL YOU GET THIS FIXED or you will be replacing head gaskets if that isn't needed already. It seems as though your EGR cooler is ruptured. Jack the back of the truck up so the nose is down hill. Pull the EGR valve and see if it is wet in there with antifreeze. I expect that it is. This will let you know your egr cooler is ruptured. If it ruptured it is because the oil cooler is clogged. That's the progression. If you continue to operate in this condition the head gaskets will go (if they haven't already) and possibly worse thing like warped heads. If the egr cooler rupture gets bad enough your engine will hydrolock and then your really FUBAR. So fix it now. |
Like PGreen said if it is damp EGR cooler this may help when you go to clean it if you have never been there![]() Diesel Technician Society Diesel Technician Society and if you need a cooler here is one of the better one's BulletProofDiesel - Darn-Near Bullet Proof Diesel Products for your 6.0 or if you are going to delete RCD EGR Cooler Delete GoGoDiesel EGR Delete System The most advanced EGR delete system for your 6.0L Powerstroke. Hope this helps ![]() 2 stroker |
I pulled the EGR valve the other day and didn't see any antifreeze standing in there but it did apear a bit damp. I'm going to do the work as soon as I can get some parts in. I was just looking opinions of what else to do while I have it down with the turbo and intake off of it.
while your at it, clean up the turbo too
Hey man welcome to the 6oh cummunity. Sorry to hear about your misfortune with your truck. I am pretty new to these trucks too. Ive had my 2005 f250 xlt psd for about a month now and there is a lot of info on here about these trucks and these engines. I started my mods with a 4" turbo back mbrp exhaust and a sct x3 tuner with custom tunes from Eric at innovative diesel. This really woke my truck up she really hauls a$$ now. I was told that the stock intake on our trucks is more than sufficient up to around 500hp. Just thought I would give ya some ideas for some mods once ya get your truck back to normal. Good Luck!!
I heard about the same as far as the stock intake being sufficient but is there a filter element out that will clean about as good as the stock one that is cleanable and reusable, $75 for an air filter change will get a bit pricey after awhile, just going off the price I saw for a Fram at Wal-Mart.
Here some talk about the Edge Insight, anyone know which would be the best to go with I see a model 83400, a CS and CTS. |
