How to install Fuel pressure Gauge?? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-13-2010, 01:08 PM Thread Starter
RoCkfiSh363's Avatar
I'm wanting to put in an autometer fuel pressure gauge. My question is which one should I go with (electric or mech) and how do I put it in? I'm probably goin with an airdogg 2 real soon as well. Any wisdom?
05 EX Cab Short
8 inch Fabtech
38 inch SSRs on 17x10 Centerlines(powdercoated)
SCT Innovative tunes
Banks CAI
Offroad MBRP Stainless 4.5 " and up pipe.
Auto Meter EGT, Fuel pressure, Trans Temp, Oil temp, water temp gauges.
Blue spring , bored 3 hole banjos.
ARP Studs
OEM Ford gaskets.
EGR Delete, cooler delete.
Bulletproof stand pipes
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
Innovative 48v FICM Performance flash.
RoCkfiSh363 is offline
post #2 of 4 Old 10-13-2010, 01:27 PM
fordfan30's Avatar
Electric if your mounting it in the cab. Mechanical only if it is under the hood. If you get a fuel leak you dont want that inside your truck. There is an adapter you will need also. I forgot where I got mine, I think Sinister or ITP but I could be wrong.
06 F250 4x4 ecsb, lowered 2", 6 Autometer Phantom 2 guages, Accufab Elbow, Zoodad, Airaid , Magnaflow 4"dp, 5" pipe 7" short stack, Studs, Egr delete, sneaky pipe, regulated fuel return, 6.4 banjo bolts, Moderate FICM from Innovative, High idle and foglight mods, Bilsteins, Sulastic shackles, DIY Harley headlights and traction bars. 8.76 in the 1/8th
fordfan30 is offline
post #3 of 4 Old 10-13-2010, 10:44 PM Thread Starter
Ha, yeah, I hate getting diesel in the face while driving down the highway Where exactly do you install the sensor? Do ya need to empty your fuel line of diesel first? Sorry for the newbie questions.
05 EX Cab Short
8 inch Fabtech
Banks CAI
ARP Studs
OEM Ford gaskets.
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
post #4 of 4 Old 10-13-2010, 11:00 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
You can get the adapter from ITP You can put the adapter into the fuel pressure test port. Here is a link to show you where to find the test port.
http://www.backglass.org/duncan/ps60...l/ps60_030.jpg
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
