What to do? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-12-2010, 09:00 AM Thread Starter
superhick8160's Avatar
Question What to do?
Ok Im getting ready to pull the trigger on an SCT tuner and I dont know if I should do head studs before I put a tuner on my truck or not. I do have the EGR delete so that part is done. I know that Im going to put all of my gauges on first before I tune it.(Fuel PSI, EGT, ect.) I guess my question is do I wait and do head studs before they blow or just do the studs when they blow and kill two birds with one stone.
2004 F-250 FX4 Lariat with the usual goodies.....
-Summer time life consumer.
superhick8160 is offline
post #2 of 7 Old 10-12-2010, 09:13 AM
I would wait with the EGR delete that is a + so if the tunes a not to hot it may last a long time that way you could save your $$$$ in time it will let go
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #3 of 7 Old 10-12-2010, 09:20 AM
mcflan's Avatar
Feedback Score: 9 reviews
Do you tow a lot? I had gotten away with not doing the studs and I've been tuned for quite some time now. Was tuned for several months without studs and finally went ahead and did it. It's all a matter of personal preference. Preventative maintenance is always a plus; especially if you can do it yourself. But, if you pay to have it done a reputable diesel shop is gonna charge you upward $2,200+
Jon
03 6.0 F350 SD
SCT w/Matt's SRL
Zoodad
AFE Stage II
EGR Delete
Banks Monster Exhaust
Isspro Gauges
Studded, Lapped, and Bored
175cc Injectors
Powermax Turbo
Blue Spring FPR
Diesel Site Coolant Filter
AD2 Fuel System
Oil By-Pass System
My personally made Remote FICM/Board
mcflan is offline
post #4 of 7 Old 10-12-2010, 09:23 AM Thread Starter
I dont tow anything really and this truck is mostly my DD. I was not wanting to put a really aggresive tune on it just maybe a tow tune or something to get a little better MPGs.
post #5 of 7 Old 10-12-2010, 09:25 AM
mcflan's Avatar
Then you'd probably be alright with not studding the truck for a while. If you're not an aggressive driver, then you're good man.
Jon
03 6.0 F350 SD
SCT w/Matt's SRL
Zoodad
AFE Stage II
EGR Delete
Isspro Gauges
175cc Injectors
Powermax Turbo
Blue Spring FPR
AD2 Fuel System
Oil By-Pass System
mcflan is offline
post #6 of 7 Old 10-12-2010, 09:29 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
I ran DJ's Looney as my daily tune for 30k miles before I broke down and got mine studded and I don't baby it by any means. With the egr delete your odds of being ok are much better. I would wait until it is needed.
RIP Mitch
the Org crew
PGreenSVT is offline
post #7 of 7 Old 10-13-2010, 12:16 PM
duc796's Avatar
You should be safe with a tune without doing studs. From what i hear if you run the custom street tune from innovative on an sct that gives you your best mpg as long as you can manage to keep your foot off the floor. The tunes can also turn your egr off as well so that helps too.
2005 Ford F250 CCSB 6.0 XLT 4x4
-SCT X3 W/ Innovative and Spartan Tunes
-4" MBRP Turbo Back Exhaust
-MBRP Cat Delete Pipe
-S&B Cold Air Intake
-Amsoil Everywhere
-CAT ELC
-Zoodad Mod
-Edge Insight CS with Pyro
-Sinister Diesel Coolant Filter
-Studded and Deleted
-6.4L Banjo Bolts
-2.5" Top Gun Customz Leveling Kit
-Bilstein 5100 Shocks
-35" General Grabber AT2s
Best track time: 14.1 @ 96MPH
duc796 is offline
