towing more power?
i want to get all i can get for towing heavy stuff without having to build my trany. i have custom tunes now and its good power im gonna get studs and egr delete soon but what eles can i do for towing?
One item that you can get that will increase power and drop egt's is a larger turbo. The powermax is highly recommended even for stock trucks.
ok so i want have to upgrade my trany or injectors?
You can if you want to
i dont really want to but will it push it ok without injevtors?
Yes both of my 6.0s have the powermax and my 07 F-350 tows 20k regularly and still has stock sticks.
ok good i was just worryed bout it now spooling fast but thanks
A Powermax and Innovative 8-Hole 155's would be a perfect combo for towing, but still great to play around with on the Xtreme Street tune. And with the 8-hole 155's, you should see a pretty significant bump in fuel mileage.
yeah true but would i need to do somethin to my trany by gettin a bigger turbo and the tow injectors from inno? i want to do all i can without messen with the trany.
Don't worry about your tranny. The Torqshifts can handle upwards of 500 HP. As long as you keep up with fluid and filters you should be fine. There are plenty of guys running 190's and a Powermax with a stock tranny.
Also, FICM tuning would be a good thing to add to that list. |
