intake elbow and cai - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-02-2010, 11:02 PM Thread Starter
85pickup4x4's Avatar
how much of an advatage does the intake elbow give you over stock, and what about also putting another intake set up beyond that. like cai or s&b?? how much of a difference would having a 2 part intake make on air flow?
85pickup4x4 is offline
post #2 of 6 Old 10-02-2010, 11:09 PM
powerhoghp's Avatar
The intake elbow is mostly cosmetic and if you want ports for boost, meth, nitrous, propane, etc. Yes, it may have a slight effect, but not one noticeable on a dyno, pyro, or seat of the pants. As for the CAI, it will vary from truck to truck, but you will feel an increase and hear a more pronounced turbo whistle. As for what CAI to get, look at the aFe stage 2 with proguard 7 filter or the S&B CAI.
powerhoghp is offline
post #3 of 6 Old 10-04-2010, 03:20 PM
Neither are worth the money. They both look pretty if you have money burning a hole in your pocket though...
Former 6Leaker owner
Newman is offline
post #4 of 6 Old 10-29-2010, 11:25 AM Thread Starter
so what would be the best intake to get for my 03 250? this is my main concern right now. im also trying to get an exhaust but all i want to do is delete the cat and the muffler. are there any kits to do that?
post #5 of 6 Old 10-29-2010, 11:30 AM
back in the saddle
shu873's Avatar
I like the AFE with a pro guard 7 filter. S & B is also a good choice and less expensive. That being said you won't notice any seat of the pants HP difference with either. Unless you're trying to squeeze everything you can out of the truck or building a high HP motor the factory intake is just fine and NOTHING aftermarket will filter better than the stock filter. The intake elbow is also nothing more than cosmetic. The real airflow restriction on a 6.0L is in the intake manifold itself.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #6 of 6 Old 10-29-2010, 03:47 PM
If you did want to go with the CAI as well as the intake elbow I think this might be a decent thing to look at. Both for $550 and then a $100 rebate. What I'm thinking about
S&B Intake Elbow & Cold Air Intake Combo 73-1003 73-1003 | Air Intake | 03-07 6.0L Power Stroke | Ford Power Stroke | Diesel Power | Performance Truck Products
2006 Ford F250 4x4 Lariat CC Stone Colored with 2 tone Tan Bottom
ZooDad Mod, S&B CAI, SCT Tuned by Gearheads, 4 " MBRP Turbo Back Straight Pipe
Wishlist:
  • 285/75/17 Fierce Attitude M/T's
  • 2.5" Leveling Kit
  • Heated & Power Tow Mirrors
  • Bulletproof EGR Cooler, Head Studs, Gaskets, and Oil Cooler
Who wants to by all this for me??
philva13 is offline
