Garrett Powrmaxx or Elite VGT-SR - Ford Powerstroke Diesel Forum
Old 10-02-2010, 12:45 PM
looking to upgrade my turbo on my 07 6.0 its my daily driver. i dont pull at all and i want to continue running stock injectors which turbo do you think would be best? thanks
Old 10-02-2010, 01:03 PM
Why would you want to upgrade it under these circumstances?
If your not pulling AND your going to keep your stock injectors, throwing a grand or more away isn't going to do that MUCH good
Old 10-02-2010, 01:25 PM
I plan on upgrading to some elite stage 1 or stage 2 injectors in a month or so
Old 10-02-2010, 01:27 PM
But you said that you're keepin stock injectors..
So by the time you get the new turbo on, you'll be installing injectors?? soooo??
Old 10-02-2010, 01:39 PM
I will have the stock injectors running on it for maybe a month or so then I'm swapping them.
Old 10-02-2010, 01:40 PM
Once you swap injectors, you're going to want to change your turbo set-up or you're gunna be
pooping smoke all over the place most likely.. Especially if you get the stage 2s.
So to me, it makes sense to get the turbo for a set-up with aftermarket injectors..
Old 10-02-2010, 01:49 PM
I do plan on that I said I want to purchase the turbo first and then I'm going to purchase the injectors about a month after I'm just waiting on the funds for the injectors
Old 10-02-2010, 01:58 PM
You're stock turbo should be good with stage1s..
And if you go stage2s then you're going to have to get a turbo and oil system upgrades..
So your cost ratio for stage1 vs. stage2 is about 1:3..
lol
Old 10-02-2010, 06:43 PM
say no to rolling coal
To answer the original question since the thread went off the reservation...
Garrett powermax over the elite turbo any day. Powermax is a brand new factory modified unit. The VGT-SR is a stock sized replacement turbo that is remanufactured.
Old 10-02-2010, 06:50 PM
I take 50% responsibility of that.
lol. I just figured why get a turbo for an engine with stock injectors when you're
going to upgrade soon??
