MPG for 6.0? - Ford Powerstroke Diesel Forum
Old 09-30-2010, 09:27 AM
MPG for 6.0?
If I install a chip for a 2004 F250 how much should if inprove my miles per gallon? also what kind should i put in?
Old 09-30-2010, 09:35 AM
Almostdunfukinwidit
Get an SCT with custom tunes. Also gauges and an exhaust.
MPG increase will vary with your right foot
Old 09-30-2010, 09:36 AM
Dont put any chip/programer in a 6.0 unless you have arp head studs. I have a 04 6.0 and just put a new egr cooler and oil cooler in. Three months later blown head gasket. We never pulled anything with it, it's my wifes excursion, I put a hypertech programer in it to help mpg and it cost me big. If you want to help mpg put a exhaust on it.
Old 09-30-2010, 09:41 AM
Almostdunfukinwidit
The programmer had little to do with your issues. The clogged oil cooler took out your gaskets
Flush the ford coolant replace with a non silicate ELC and add a coolant filter or you will be doing it all over again
Old 09-30-2010, 09:42 AM
Almostdunfukinwidit
You can run a decent tune on a 6.0 without studs. Thousands of people do it day in and day out.
As said above the best thing anyone can do to a 6.0 is get the ford coolant out of it and replace it with a non silicate ELC
Old 09-30-2010, 10:36 AM
Dave, Can you get a coolant filter at an auto parts store or is it a part you have to order?
Old 09-30-2010, 11:43 AM
Feedback Score: 8 reviews
i run a sct on stock head studs. its all about the maitenance
Old 09-30-2010, 11:44 AM
Tunes, Exhaust, egr delete will be the biggest improvement.
Innovative diesel tunes
Old 09-30-2010, 01:25 PM
Feedback Score: 9 reviews
For stock head bolts, I recommend Matt's SRL tune from Gearhead. He tunes the file with less cylinder pressures than stock, and claims to have a perfect record with non-studded trucks.
Old 10-01-2010, 12:16 PM
Thank you Dave for clearing that up sometimes when the manufacturer puts out a statement like that the customers think we are just trying to get around something. Our unit works great with the 6.0.
