EGR delete? - Ford Powerstroke Diesel Forum
post #1 of 33 Old 09-29-2010, 04:49 AM Thread Starter
jtk27's Avatar
EGR delete?
OK I wanna put a delete on by sinister or rcd but have a few questions. MKM's website says that for the 05 if you leave you EGR valve in place and plugged in that it should fix getting a light on. This is contrary to most of what I've read where you need a tuner to do away with the light. I've read on an 05 that all it looks at is if your valve is opening and shutting like it should, even though it's blocked, then it thinks everything's fine and won't throw a light. I want to delete my cooler because it scares the hell out of me but I don't want to do a tuner yet but I also can't stand a light in my face all the time.
05 F250 King Ranch PSD 4x4
-ARP head studs with factory ford gaskets
-Updated oil rail plugs
-Liberator diesel Y-pipe
-SCT X3 Custom tuned by Eric
-Dieselsite Coolant filter kit
-High Idle Mod
-Edge Insight CS w/EGT
-Sinister EGR Delete
-Prestige Remote Start
-Upgraded turbo drain tube
-Upgraded HPOP connection
-Blue spring kit
South Central Oklahoma Ranch Hand Accessory Dealer
jtk27 is offline
post #2 of 33 Old 09-29-2010, 05:25 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 24 Post(s)
Feedback Score: 4 reviews
Well, Ford got a little sneaky with the last reflash for the 6.0. They made it to where if the EGR valve isn't plugged in, the clutch fan won't work . Do youself a favor, and buy a unit that will monitor ECT and EOT, make sure the delta isn't spread anymore than 15* while cruising on the hwy. If you want to keep it stockish, replace the cooler with a Bulletproof cooler, and rebuild your oil cooler, install a coolant filter as well
PS of the two delete kits you're looking at, use the first one you mentioned
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #3 of 33 Old 09-29-2010, 05:35 AM
HOTWHEELS34's Avatar
I deleted mine and I have yet to get a CEL when running the stock tune. I aslo left the valve in place and plugged in.
2005 F350 CC SB ,Turbo-back Silverline 304 ss , RCD EGR delete , Elite VGT-SS turbo , SCT tunes by DJ's , cat delete , Autometer triple gauges , 20" MKW M19 , Toyo 38 x 15.50 x 20 , Icon 4-link 10in. lift , Dual Sway-a-way coilovers and shocks , Pioneer Avic F90BT, OUO Driveline Drop, CCV reroute , FS-2500 oil bypass, Mag-Hytec diff covers , Amp steps
Wanting a Cummins swap.
HOTWHEELS34 is offline
post #4 of 33 Old 09-29-2010, 09:28 AM
hazard's Avatar
Everyones gonna tell you to go with the sinister kit...seems to be the flavor of the month, everything from rcd has been made out to be junk and cust service is bad, I haven't had any issues but everyone else will complain.
Thanks,
Adam
2006 F-250 6.0L CCSB Lariat 4x4, ARP studs, SCT tunes by innovative diesel, Silverline 4" turbo back exhaust no cat no muffler! Upfitter switches w/high idle mod, Edge Insight monitor w/EGT probe, autometer fuel psi gauge, Zoodad mod with billet plate. Ford Updated fuel psi spring and banjos, RCD egr delete, Ford updated oil cooler and stc fitting, dieselsite cac boots and coolant filter.
1984 Mercedes Benz 300D Turbo Diesel, cold air intake.
"Run Hard, Dream Big"
hazard is offline
post #5 of 33 Old 09-29-2010, 09:39 AM
2005 is a tricky year for the egr delete. Some 2005 trucks will throw a code some will not. It just depends if it has a sensor in the intake which monitors the egr cooler flow. My recommendation to most customers with 05 trucks is to buy the egr delete kit try leaving the egr valve plugged in and mounted in the intake and see if it throws a code. If it doesn't great if it does well then you will need a SCT tuner with custom tuning if the check engine light bugs you. Although an SCT is defiantly not a bad accessory to have on your truck
Brian George
Brian@sinistermfg is offline
post #6 of 33 Old 09-29-2010, 09:42 AM
mxrider777's Avatar
If you use a tuner/programmer to get rid of the check engine light when you use an egr delete kit will the clutch fan work again?
mxrider777 is offline
post #7 of 33 Old 09-29-2010, 09:46 AM
PGreenSVT's Avatar
Feedback Score: 3 reviews
Buy a set of their junk injectors. Then after several warranty returns and continued junk injectors, the hassle and expense of continually swapping them out, truck running like crap, try to get a refund.
Their egr delete is not a crappy product though IMHO not as nice as the Sinister. Their rep for crapping on customers who have bought their lousy injectors and not standing behind them make them a company that many of us who really care about this hobby have chosen not to support. Dollars talk and they will not clean up their act unless it hurts them in the pocket. Unfortunately with the internet there are enough unsuspecting buyers that they can continue to prey on uninformed newby's and first time buyers and not rely on repeat business. I won't buy anything from RCD because of their business practices. I don't recommend anyone else do business with them either.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #8 of 33 Old 09-29-2010, 10:47 AM
hazard's Avatar
That does suck, it happens though its too b ad they aren't backing their products better...but their egr delete is a very nice one quality welds and good materials I'm satisfied and you can get them on ebay for 175 bucks I believe fast shipping too. Just look everything over good before you install to make sure all is good. Mine has worked awesome so far.
Thanks,
Adam
hazard is offline
post #9 of 33 Old 09-29-2010, 10:59 AM
bfrank81's Avatar
Same here!!!
Brian
'05 F250 Harley-Davidson
bfrank81 is offline
post #10 of 33 Old 09-29-2010, 08:50 PM Thread Starter
jtk27's Avatar
OK before we get too far off subject which pgreensvt has had a habit of doing with my threads before. Just a friendly jab dude, I like your advice and listen to you. It sounds like you just have to try it and see and hope. The other thing that concerned me in the instructions to sinister's kit is just lifting the intake on the right side and putting it back down. I like it in theory because it saves me time and labor but does anyone see a downside like gaskets not sealing well once they've been lifted like that. Thanks.
-High Idle Mod
-Blue spring kit
jtk27 is offline
