03 Turbo boost
I have an ISSPRO boost gauge run to my intake manifold and running the SCT with IDP custom tunes I have seen 40 PSI of boost stock turbo. Doing a little more research I have found that the inlet just before the compressor is approx 3/10 in larger than the 05,06, and 07. I am not sure if thats the reason why or if its the 9 vanes that the 03 turbo has.
What for boost has anyone else seen with they're truck? |
Most i have seen with my stock 06 turbo was 35psi.....30psi with the stage 1 turbo
40 lbs sounds high! Most I've seen running a hot SCT file was 35ish. I did see 40 lbs when the vanes were sticking.
I only hit about 28psi with my 03 turbo.
Most 6.0 guys I talk to say that 32 is about the max... I am not sure what the computer reads and how accurate the computer reading actually is... But I know what the gauge says and thats 40. Mind you thats not all the time and thats the max I have seen
The most I have seen out of my truck is 27 or 28 psi! 2003 F250
Me too, when I had the stock '03 turbo I'd max out at 35psi with an extreme files. With the stage 1, max is 30psi with extreme files.
Maybe the standard trans helps out some
