installing edge - Ford Powerstroke Diesel Forum
Old 09-15-2010, 05:11 PM
installing edge
I am getting ready to intall an edge insight and probe in an 03 6.0. Is this a hard job and is there any tips i need to know? Any advise on what i need to becareful on. Thanks
Old 09-16-2010, 08:22 AM
Take your time drilling the manifold, the directions that come with it are pretty good, just be careful so you don't break a bit or a tap, when your finished drilling it and tapping the threads stick a small magnet in the hole and try to grab any metal shavings that may be in the manifold, then I started the truck with the hole open to blow anything else out, I don't think its necessary though its up to you man. Then install the pipe fitting and install the probe, its a very easy procedure, as I said the directions are pretty good then route your wiring and hook up the monitor to the obdII port and set up the insite settings and your ready to go hope this helps!
