SCT tuner tire size/mph/mpg adjustment? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-14-2010, 05:49 AM Thread Starter
Unhappy SCT tuner tire size/mph/mpg adjustment?
I am sure someone has covered this, but I tried to find it and can not. I purchased an SCT X3 from Stealth, and forgot I upgraded my tires to 35's after adding a lift kit.
I was reprogramming after towing this weekend and realized I never set the speed/tire revolutions, so I tried and I am totally lost.
Can someone with some knowledge on this help. I know it has a tire rev per mile or something but all the numbers were "stock size" and in the 500's. From my math I am making something like 1080 revs a mile or something, so I do not get it.
If anyone remembers the setting to put it on for 35's I know a lot of members run them.
Thanks!
madcat6183 is offline
post #2 of 11 Old 09-14-2010, 06:35 AM
Abrannan19's Avatar
Feedback Score: 5 reviews
what is your exact tire size, make and model?
Adam Brannan
First Coast Diesel Performance
Abrannan19 is offline
post #3 of 11 Old 09-14-2010, 06:44 AM
Matt@SCT's Avatar
For the 6.0 Diesel's we can not correct the speedo. The Abs controls the speedo and we are working on flashing the ABS system but we dont have a eta on release.
Matt@SCT is offline
post #4 of 11 Old 09-14-2010, 06:47 AM
Abrannan19's Avatar
no the SCT wont correct the speedo but, in order to get your shift points dead on with the larger tires you need to set the rev per mile correctly.
Adam Brannan
post #5 of 11 Old 09-14-2010, 06:52 AM
Matt@SCT's Avatar
Yes that is correct the tire revs is to correct the transmission shift points with the bigger tires.
Matt@SCT is offline
post #6 of 11 Old 09-14-2010, 07:05 AM Thread Starter
Gotcha, intesesting all. Its an 05 was on stock 17s now on 18s with 35/12.5. Will go back to 17s with 35/12.5s for winter.
It is lifted 4.5 inchest as well.
Thanks for all your help, I just want to be able to actualyl figure my mpg correctly because it is telling me on economy or street tune I m still getting 13mpg and 10 mpg towing 7k travel trailer on tow mode. I neve rreally mapped something and figured it all out because I usually get fuel anytime I see it cheap.
Thanks.
post #7 of 11 Old 09-14-2010, 07:13 AM
Abrannan19's Avatar
In order to get the correct revs per mile, you can look up the brand of tires, model and size on the manufactures website and it will tell you what the revs per mile is.
just so you know, setting the revs per mile correctly will not change the odometer either. You will need to add something such as a speed wizard if you are trying to correct the speedo and odometer. Since the tires are only 35's ford can recalibrate the speedo very close to 35" tires.
There are other methods of figuring MPG. You need to figure out how many mile your speedo is off, typically this can be done on an interstate going from mile marker to mile marker, looking at what your ODO shows vs. what the mile markers tell you.
Adam Brannan
post #8 of 11 Old 09-14-2010, 09:26 AM
Davey~do's Avatar
Autoenginuity can do this as well.
Davey~do is offline
post #9 of 11 Old 09-14-2010, 10:41 AM Thread Starter
Dang I was definitely under a different impression on the tuner then and it's capabilities. But either way, sounds like changing that on the tunre is basically pointless.
post #10 of 11 Old 09-14-2010, 11:33 AM
SickStroke6.0's Avatar
Feedback Score: 9 reviews
Check out the sticky "Tire Revs Per Mile."
Blake
2013 F-150 CCSB Oxford White FX4 EcoBoost
Loaded with every option...
2008 F-250 CCSB Dark Copper King Ranch 6.4L FX4
4" MBRP Exhaust w/ Muffler (DPF/DOC Delete), Modded Stock Intake, H&S XRT Pro
SickStroke6.0 is offline
