lift kit please help - Ford Powerstroke Diesel Forum
Old 09-12-2010, 04:00 PM
Smile lift kit please help
im looking at lifting my 2003 f35 with a six inch lift. do i need to do a drive shaft mod or will it work. also is there any other mods i need to do before i install it such as brake lines ect
Old 09-12-2010, 08:41 PM
brake lines will work, front driveshaft is fine at 6 inches, rear driveline you can use a spacer to drop the carrier bearing(where the two piece driveline is connected) drop it down till its as straight as possible,... it will alwayss vibrate when you take off though as it flex'es under torque with the higher angle and bigger tires.... only way to fix it is a one piece driveline... but you can do that later if it is an issue, any lift kit will come with some sort of spacer to drop it down
