What Part Next? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-08-2010, 05:56 PM Thread Starter
Galaxie's Avatar
What Part Next?
So, my 06 is tuned, studded, and EG cooler is gone. I only have 39k on her. My question is what other fixes are needed with our 6.0s? I know the cooler and studs are just about necessary. I am planning on keeping this truck for A LONG TIME. I can typically get 140-180k out of a gasser so I plan on having this girl even longer than my gassers.
Why coolent filters? Why oil cooler upgrades? What gauges are nessisary?
Thoughts?
Cheers!
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #2 of 8 Old 09-08-2010, 06:04 PM
jesilvas's Avatar
Quoted: 2 Post(s)
The blocks are sand cast. Fine sand is left in there. Same with 7.3s. So the quicker you get that fine sand out, the longer the internals in contact with coolant will last.
Gauges because you don't wanna blow your turbo with too much boost, don't wanna melt your pistons with too much heat, don't wanna melt your trans the same way. I know the oil cooler on the 6.0s can go out. Idk how or why but they do. So if you monitor the diff between the EOT and the ECT and the diff is more than a certain amount (like 25*s?) then you know the cooler might be starting to go.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 8 Old 09-08-2010, 06:10 PM Thread Starter
Galaxie's Avatar
Good info! I didnt know about the sand casting. Cool! I need gauges!
Colin
87/93 5.0s 347
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Blue Spring
03 Turbo
Galaxie is offline
post #4 of 8 Old 09-08-2010, 06:30 PM
Edge Insight instead of individual gauges. I could take four of the five gauges I have out of my truck now that I have it.
2004 CCSB -mods:
* H11 head studs
* ZooDad Mod w/ Custom Intake Inlet & Grill
* Banks High Ram Air Intake Manifold Elbow
* Banks Techni-Cooler Intercooler
* Banks 3.5" Boost Tubes
* (3) Dieselsite 3.5" Banks Replacement Boots
* FICM Programmed by PHP
* Stage 1 Regulated Return Fuel System
* 0-100psi Fuel Pressure Gauge at Regulator
* Adjustable Fuel Pressure
* EGR Delete
* Banks 4" Monster Dual Exhaust
* Edge Insight CTS
ImaPoser is offline
post #5 of 8 Old 09-08-2010, 06:47 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Fuel Pressure gauge, when the FP drops to or below 45psi you take a chance of destroying injectors.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #6 of 8 Old 09-09-2010, 03:25 AM Thread Starter
Galaxie's Avatar
How does that one work?
Colin
87/93 5.0s 347
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Blue Spring
03 Turbo
Galaxie is offline
post #7 of 8 Old 09-09-2010, 03:46 AM
Plugs in to your OBDII port and you can set it up to display a multitude of different data fields. I have mine set up to show five things at once, ECT, EOT, TFT, boost, and load. They are working on adding more stuff in the future, if they take suggestions and wishes, they will find a way to add fuel pressure and oil pressure.
2004 CCSB -mods:
* H11 head studs
* EGR Delete
* Edge Insight CTS
ImaPoser is offline
post #8 of 8 Old 09-09-2010, 04:14 AM
diablos30's Avatar
Quoted: 31 Post(s)
Replaced oil cooler still difference in temps
check out the last page of that thread for more information on why a coolant filter is a must.
also based on what is posted there i would either switch to an elc coolant (highly recommended) or plan on changing out the oem coolant alot more frequently.
diablos30 is offline
