Scangauge help? - Ford Powerstroke Diesel Forum
Old 09-08-2010, 03:19 PM
Scangauge help?
I just picked up a scangauge II as an affordable way to check a few things on my truck with a 6.0.
I'd like to see boost, EOT, and ECT. The manual is useless, and the support line hangs up on me. Anybody have any tips before I send this POS back?
Thanks-
Old 09-09-2010, 06:41 AM
This gauge is great! Don't send it back! You won't be able to read boost. I've got mine configured to read ECT, EOT, Trans, Volts, to display.
I'll see if I can find some information on the codes and sequence on configuring these parameters.
Old 09-09-2010, 06:47 AM
Subscribed
Old 09-09-2010, 07:24 AM
I'd love any info you can find! I wanna start watching my EOT and ECT as soon as I can.
I played with it for a while yesterday, but was pretty frustrated after a long day of unsuccessfully trying to install a fuel pressure gauge and upgraded pressure regulator on my van. All sorts of **** has to come out of a van just to get to the topside fuel filter, and then the return line would not come off even with two of us hauling on it. Not much room to turn a long armed wrench under that van hood.
Old 09-09-2010, 03:25 PM
just go to thier website, the entire 6.0 protocol list is there. there are alot of digits to install, just take your time the scangauge works very well.
boost is available, i can't remember where i got the protocol at, but i have it loaded on mine. i have the factory boost gauge and don't really need it. if you need the boost after you get everything else loaded let me know and i will pull it from mine and post it up on here
Old 09-14-2010, 10:23 AM
Hey Roadrunner - I got the others figured out, but can't find boost listed anywhere. If you get a chance to pull those numbers I sure would appreciate it.
Old 09-14-2010, 01:09 PM
Here are the numbers for the 6.0 boost;
686AF1010B TXD
0041850B0000 RXF
2808 RXD
00910064FF88 MTH
plug those in and see what you got
