First F250, want to add upgrades - Ford Powerstroke Diesel Forum
Old 09-03-2010, 12:07 AM
hey buddy's, i just got my first 2005 f250 FX4 6.0L. Want to add custom upgrades and would like to have some guides, and what i should do or best for my truck.
Heres a little about my truck. I currently have 98,000 miles, prelifted from ford, about 8 inch with 37's toyo on 20. I get poor gas mileages, on highway 8.3 mpg, on freeway 10.4 mpg (average). how i figure that out? i pump full tank reset the mileage and drive till whenever gas go out and pump again and see how much gallon i had pumped and how many miles i had put on. For example 219 miles/ 28 gallons will give me the mpg. the other thing is that i have fluid leaking but its not diesel, and other bad thing is the steering has a play in it (was thinking power steering fluid leaking?) but then again its not red fluid? please help...
Here are the upgrades i bought so far...
Rize 12" lift kit
king coilover
fox shock
icon spring
axle w/4.56 gears and w/arb lockers
22 xd diesel on 40's toyo
here are the upgrade i want and need
programmer (sct livewire 9600, bully dog triple, edge w/attitude platinum) which one is best to get or none, your opinion?
do i need arp head stud?
EGR delete? heard of it dont know what is it.
MRBP single 5-6" exhaust
Intake, what brand are nice?
will i be saving more gas with tuner and all?
what do i need to run my lift kit and my 40's?
anything i should do before i add performance?
need to change my oil, what you recommand?
powering fuild change and tranny, whats all needed? and how many fluid?
may seem like i dont know how to fix cars, but i do know how to fix my toy car just not an diesel truck, my brother will be helping me and he has certified from UTI. any info would be great and thank you all for helping.
Old 09-03-2010, 04:36 AM
Sct is the way to go for programmers. Lifting the truck usually decreases your mileage. 40" tires decrease your mileage. 4.56 gears will help with the 40" tires. You don't "need" an intake. The factory intake is good to about 500hp or so. Egr delete is a good idea. Sinister, RCD, FCDP, Gogo Diesel all make good products. MBRP makes a nice exhaust. No need for more than 4" but a 5 " sounds nice too. Use the proper Motorcraft or Racor filters only. For oil I like Amsoil and Schaeffer in 5w40. Valvoline extreme blue 5w40 has been pretty good according to many. People seem to be having good luck with Rotella T5 10w30.
GAUGES/SYSTEM MONITORING! Get some! I like the Edge Insight. You need to be able to monitor EGT, EOT, ECT, fuel pressure, trans temp if you tow, etc.
Old 09-03-2010, 05:47 AM
Just to add to what PGreenSVT said you didnt say if you corrected for your tire size when you calculated your mileage. It might be 10-15% better than you think but that still is not to good.
Old 11-29-2010, 09:43 PM
thanks for the help guys. i have change of plans, going to sell my truck and get an harley i really like an harley edition. going to install all the performance on to that
Old 11-30-2010, 05:25 AM
Or
Or you can sell both your trucks...and go on vacation....
Good luck man.
Old 12-02-2010, 01:32 AM
vacation sounds good but its weather, only vacation to the snow , and thanks hope it sells so i can get what i always wanted!
