Coolant filter questions?? - Ford Powerstroke Diesel Forum
Old 08-31-2010, 12:07 PM
Send a message via AIM to Powerlift34
Can I please have some opinions on coolant filters? Who sells the kit,ect? Any pictures and write ups on intalls? Btw on a 05 6.0.
Old 08-31-2010, 12:11 PM
Here you go get the 2 ball valves and 3 filter to start it works
http://www.dieselsite.com/index.asp?...ROD&ProdID=324
2 stroker
Old 08-31-2010, 12:16 PM
Feedback Score: 5 reviews
we have a coolant filter kit available:
First Coast Diesel Performance -Product- Your Source For Powerstroke Performance
Old 08-31-2010, 02:31 PM
Is there any benifit even if I have the egr delete? And is there any install pictures? Someone needs to do a write up of an install.
Old 08-31-2010, 03:16 PM
yes it will keep your oil cooler from getting plugged up and protect your water pump.
Old 08-31-2010, 03:22 PM
I personally got mine from dieselsite.com. Them and FCDP make great kits. It is an important mod. It will save your oil cooler as mentioned above. The install is very easy and the kits will come with directions, with pictures.
Old 08-31-2010, 06:57 PM
I too have the Dieselsite kit. Great quality product and easy to install. You will be shocked when you change your first filter and discover how much sand and grit are circulating through the cooling systems of these motors.
Get one before it's too late and your oil cooler is plugged. Otherwise it's a matter of when - not if, it will plug.
Old 08-31-2010, 07:36 PM
after my first filter change i had all sorts of gunk in it, silcate build up and gunk, much needed mod, now this weekend when i install my egr delete ill finally be putting in some worthy elc!
Old 09-01-2010, 05:55 AM
Another good idea is to dump that crap gold Ford coolant and use and ELC like Cat or Rotella or Fleetrite. Then you won't have the silicate buildup in the first place.
But, but Ford says you have to use the gold stuff. Yeah, and International runs them on ELC and doesn't have the problems that Ford has with the oil coolers clogging. Make up your own mind.
