AirdogII Questions - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-30-2010, 01:08 PM Thread Starter
04stroke's Avatar
AirdogII Questions
Ok so i installed a airdogII and it works great no problems but a friend of mine with a dodge has the airdog150 or whatever it is and he said that he installed a "draw straw" in the tank n drilled the tank n what not.. mine just tapped into the factory fitting and i didnt drill my tank..n i followed all instructions.
now hes telling me i did it wrong n that the fuel pump will have to work harder then normal..also i did happen to blow the inline fuse that runs to the battery for the pump about 3 weeks ago.no idea why tho.? When idle in park the fuel pressure is 64-68..when idle in D the pressure is 60-62. when driving the fuel pressure usually stays at 68 unless i let off the pedal it drops to around 60-64... i guess im asking if anyone else has there airdogII installed the same way into the fuel tank and what kinda fuel pressure they see at idle and cruise.?
2004 F-250 5.9
97 12 valve P-pump tuned,4k and worked!
04stroke is offline
post #2 of 8 Old 08-30-2010, 04:12 PM
Well as far as I know you installed it correctly because that's the same way I installed mine. My fuel pressure varies by + or -2psi. My average is about 64. You're well above the minimum pressure, which is 45psi. I wouldn't worry about it unless the pump is making weird noises or anything like that.
2006 F-250 XLT 6.0 Diesel
SCT with Looney Wild
ARP Studs / Cass 175s / Powermax
Banks Intercooler / Snow Stage 2 Water/Meth
4" w/MBRP exhaust + black RBP 5" tip
Air Dog II with adj. regulator
Sinister EGR Delete
20x9 Dick Cepek DC-1 rims
EGT, trans, boost, and fuel pressure gauges
DieselSite Coolant Filter
sleeper1 is offline
post #3 of 8 Old 08-30-2010, 04:20 PM Thread Starter
04stroke's Avatar
Ok thanks. no weird noises just the pressure seems to always be different..
2004 F-250 5.9
04stroke is offline
post #4 of 8 Old 08-30-2010, 04:37 PM
Have you changed your fuel pressure regulator spring to the blue one? The BB mod would give you similar results and save you $70. This helped keep my pressure a little more stable...I forgot to mention that before
Sinister EGR Delete
sleeper1 is offline
post #5 of 8 Old 08-30-2010, 04:45 PM Thread Starter
04stroke's Avatar
Nope i never changed anything? just got the pump n installed it..how much is the spring and whats it do differently?
2004 F-250 5.9
04stroke is offline
post #6 of 8 Old 08-30-2010, 04:56 PM
Well you have to buy a kit from Ford that includes the spring. It costs $70. The other parts in the kit really aren't necessary to change out so that's why I just used a BB from a kid's gun. The spring weakens over time and this will help with idle quality and fuel pressure. Here is a link to another thread that thoroughly explains what you need to do. It's pretty easy and only took me about a 1/2hr. The thread says it's for a 7.3 but works for the 6.0 too.
http://www.powerstroke.org/forum/7-3...e-install.html
Sinister EGR Delete
sleeper1 is offline
post #7 of 8 Old 08-30-2010, 05:55 PM Thread Starter
04stroke's Avatar
Awesome,ill deff have to do this. ill just use a BB since it tells you in the write up which size it has to be.
At first i thought you were talkin about changing the spring inside the AirdogII lol
2004 F-250 5.9
04stroke is offline
post #8 of 8 Old 08-31-2010, 01:30 AM
I know that someone else on here was having the same problem as you are and this didn't help him. I figured it's worth trying though because it worked for me and it's easy enough to do...good luck
Sinister EGR Delete
sleeper1 is offline
