4 Inch Duals
I'm getting ready to install the Diamond Eye 4 inch dual exhaust with the muffler and cat delete and 4 inch downpipe. Does anyone here have this exhaust and how do you like it, and do you have any tips or tricks for an easier installiation?
I know nothing but would love to see pics when ur done!!!
i got the silverline dauls the only tip i can give is jus get it in all loose then tightin everything up
here are some pics of the install of my 4 inch diamond eye straight pipe for you. i had to cut the bolt sticking out the fire wall holding the silver firewall stuff. and mine ripped the silver stuff but you can stick it right back
downpipe lossely clamped to turbo ![]() bottom of down pipe ![]() the bottom half of down pipe loosely clamped down ![]() a look at the clearance of the tranny crossmember and tranny ![]() then hang the tailpipe over axle and muffler or muffler delete(mine was the muffler delete) ![]() then i had to cut the piece to fit between but you may have a perfect piece, i have a reg cab, long bed and none of the pieces fit right so i had to cut ![]() heres a picture of over the axle clearance ![]() here is finished product after i installed the rest of the tail pipe and tip. ![]() then go back and adjust for clearance and tighten clamps starting with the turbo back. then start engine and you can cover the tip with your hand and you will be able to hear the leaks better then go and enjoy the sound. |
