Will an 03 turbo work on an 06? - Ford Powerstroke Diesel Forum
Old 08-21-2010, 11:48 PM
Did alot of searchin on the site and couldnt find anything to answer a few q's i have. I have an 06 F350 and want to swap in an 03 trubo. Did Ford make 2 turbos for that year. Cause if i remember correctly are their 03 F250's and 03 1/2 F250's. If thats right, did the turbo change at all. Also will the 03 turbo pedistal bolt up to an 06? Are they both VGT and are their any other parts recommended/required for the swap? What im looking for is the turbo whistle. I have the money for the parts and really want it done soon. More that likely ill have to have the dealer do it cause im currently in Australia and wont be able to do it myself cause im stationed overseas. Thanks for any help guys...............and girls
Old 08-22-2010, 01:46 AM
You can do the work if you understand how to turn a wrench.
The '03 turbos are not that different one has a silencer ring that can pop out.
You will need a '03 pedestal and it will bolt up to your truck.
I suggest you get an updated VGT actuator.
Get the small Ford parts kit that gives you new o-rings, bolts and gaskets.
Old 08-22-2010, 05:34 AM
Im well mechanically inclined to do the work myself but the fact that im stationed overseas does'nt help me so im just gonna pay someone to do it. Not sure where to get it done at yet, still tryin to figure that out. The truck is at my sisters house in Northern VA outside DC. In your opinion, would you go with the Garrett Powermax VGT or a new 03 turbo from the dealership while running the stock injectors/fuel system?? Ill be getting the "Complete 6.0 Solutions" from puredieselpower.com and just debating on what turbo to go with. Any help would be appreciated. Also, any suggestions to get the work done on the East Coast anywhere North of NC? Thanks!
Old 08-22-2010, 05:40 AM
What does the "complete 6.0 solutions" consist of?
I looked at their site and didnt see anything
Old 08-22-2010, 05:43 AM
EGR Delete Kit by Sinister Mfg. Company
Black Onyx Head Gaskets either 18mm or 20mm by Sinister Mfg. Company
Black Onyx Exhaust Gaskets
ARP Head Stud Set
Ford Factory Oil Cooler Kit
Ford Factory Oil Cooler Screen
Ford Factory Intake Gaskets
Ford Factory Turbo Hardware/O-Ring Kit
Old 08-22-2010, 05:49 AM
ARP Head Stud Set
Sounds like you have some good preventative maintenance planned
I really dont know much about the powermax turbo.
I say stick with the stock turbo, unless you are planning on building a high hp truck.
Even with the stock turbo, a SCT will get you to 400-425hp
Old 08-22-2010, 04:19 PM
ARP Head Stud Set
I guess cost isn't an issue but it can be done for much less. Drop me a PM with your email and I'll get you on the right track!
Old 08-22-2010, 04:43 PM
Lt. Negativity
I currently run the powermax its a good DD turbo for what your looking at doing. The cost of a powermax and a stock turbo Id go with the powermax, later down the road you can swap injectors if you decided to. Check your pm there's threads on my truck.
Old 08-23-2010, 05:06 AM
Definitely go with the Powermax and not the 03. The Powermax gives you more options and screams like the 03 turbo. Throw some new sticks at it later and it'll really wake it up.
