Aftermarket 6.0 Y pipe full solid, anybody use this?? - Ford Powerstroke Diesel Forum
Old 08-19-2010, 06:55 PM
Question Aftermarket 6.0 Y pipe full solid, anybody use this??
Hey all!
I have a leak in the expansion joint on my Y pipe, I already have the EGR delete and the stock up pipe was just blocked off. The up pipe is fine, but I found this Ford Products item, the partial Y is $225 and the full pipe set up is $325.
Anyway I was thinking of going with the full pipe cause I want that scoop out (1) and I've since read the up pipe will eventually leak without the EGR support(2)...
I am wondering if anyone has used this item and how is it, quality and fitment wise?
I have a 2006 F350 6.0 just put in 4" TB cat delete, head studs & EGR delete.
THANKS IN ADVANCE!
Darren
Old 08-20-2010, 04:06 AM
Drivin the 6.mOney pit
Feedback Score: 6 reviews
Liberator is a good kit...also check out FCDP kits which are really good as well as GOGO diesel and Sinister kits.
I myself am going to go with a GOGO diesel full EGR delete kit.
Old 08-20-2010, 04:44 AM
Lt. Negativity
Its the same thing innovative diesel has. I run the smaller version of it. Tight fit but it works.
Old 08-20-2010, 06:39 PM
cool, I think I'm just gonna order up the full pipe, I would be very jacked if I pull all that chit apart and 6months later the up pipe takes a dump. That would be my luck LOL
I think I'm gonna attempt to take apart the turbo too, and give it a clean/inspection.
