stock turbo ok with injectors.
not sure what kind of injectors i want but will the stock turbo be ok with new ones.
if you are referring to bigger, then yes to a point. 190s are about as big as a stock turbo will handle and you need fuel pulled back in the tuning. 155-175s cc would be a better match. eventually your going to want a bigger vgt turbo.
yep, Sam is correct. I have 190's on my stock turbo..I need a bigger turbo though to get the full benefit of my 190's
how much should these run me? and will i notice a big difference in power?
IM RUNNING THAT SETP UP NOW JUST FINISHED DOING STUDS,EGR DELETE AND INJECTORS YESTERDAY ILL LET YOU KNOW WHAT IT PUTS DOWN WHEN I RECIEVE THE TUNES ....
probably 3500 for casserlys, elite has some for 3000 so its not cheap. those are really the only ones you would want to get. do it once and get good ones. and yes, you will have a bit of extra power. it feels real good to have them when they work right
