Can I put a BOV in my 04 6.0 - Ford Powerstroke Diesel Forum
Old 08-15-2010, 11:55 PM
Send a message via AIM to billydakid1567
Arrow Can I put a BOV in my 04 6.0
Just wondering if I can put a blow off valve in my truck or it an internal wastegate ???
Old 08-16-2010, 02:48 AM
The 6.0 uses a VGT turbo which requires no wastegate. I guess in a way it's an "internal" waste gate. Search VGT turbo and you can read for days.
Old 08-16-2010, 05:49 AM
Lt. Negativity
Its not needed.
Old 08-16-2010, 09:12 AM
You most certainly can, is it required? Not at all but it sounds cool as crap and will impress your friends!
Old 08-16-2010, 11:46 AM
I wonder if that's what ricers say about their fart can mufflers?
Old 08-16-2010, 11:56 AM
. or just put stacks and some flame throwers in them that would cool to.
Old 08-16-2010, 09:40 PM
Ok thanks because the stock one sounds like ****
Old 08-16-2010, 09:49 PM
shhhhh, can you hear it?
In many configurations, VGTs do not even require a wastegate; however, this depends on whether the fully open position is sufficiently open to allow boost to be controlled to the desired level at all times. Some VGT implementations have been known to over-boost if a wastegate is not fitted.
quoted from wikipedia.....so ummm depending on how modded your 6.0 is you might need one.
Old 08-16-2010, 11:07 PM
Lt. Negativity
My 6.0 is modded and a bigger vgt turbo, and I still dont need a blow off valve, Ive ran Elites SS and still didnt need one, plan on running the biggest VGT possible and a buddy runs it no problem. Its all in tuning.
Old 08-16-2010, 11:08 PM
yea but if you get the chatter i would put a gate on her
