Can I swap a 03 or 04 ficm in my truck (05) - Ford Powerstroke Diesel Forum
Old 08-13-2010, 09:20 PM
Hey guys would I have to do anything to put a 03 or 04 ficm in my truck without any trouble codes ore anything like that? Also would an 05 Ficm just bolt right in and everything be just fine? Or would custom tuning have to be applied?? Thanks guys...
Old 08-13-2010, 09:21 PM
I mean would an 03 or 04 ficm just bolt right into an 05 and would a 05 ficm just bolt into an 03 or 04 without any trouble codes
Old 08-14-2010, 03:06 AM
Almostdunfukinwidit
Yes. But it would set a soft code for a non matching vin unless you had it programmed
Old 08-14-2010, 07:56 AM
Is it true that the ficms from the earlier years are a little "hotter" than the latter ones? Also a soft code... that means it wouldnt set a cel?
Old 08-14-2010, 09:22 AM
Almostdunfukinwidit
If you get an 03 FICM with the original flash on it yes thats true
As to the CEL question correct, soft codes dont set the light
Old 08-14-2010, 07:57 PM
k thanks for the info! Also whats the easiest way to check if the ficm has the original flash?
Old 08-15-2010, 07:56 PM
I pulled out my Innovative reflashed '03 FICM, and installed a new style Swamp's modified FICM with no codes, or problems at all.
