Where should I start??
So I have a 06 F350 6.0 with an Edge Juice w/attitude and a 4inch Banks Monster exhaust. I want to slowly start having some fun..and don't know where to start and I am a rookie around diesels. I hear about air intakes, studs, injectors, intercoolers, straight piping it, etc, etc! Where should I start on a budget? Thanks for any input or advise
Start by ditching the edge and get a custom tuned sct. If you use the search feature you can find a lot of threads that will answer your questions.
Start with gauges so you can monitor your vitals. Like was said ditch the edge and get a custom tuned SCT. You will also want to open up your exhaust. Either straight pipe or with a high flow muffler.
As far as asking questions ask away. What makes this place great is we are not normally a group of people that tells you to use the search feature and will answer your questions no matter how many times we have done it before. |
Thanks for your help!! |
The exhaust depends on what sound you like. 6.0's are loud under load without a muffler so some folks like it in, some folks like it gone. I don't have either of those pieces of equipment and love the way it sounds. |
if you dont have an intake its no big deal. your stock one will flow more air than any aftermarket. unless you want the cool sound that is.. i wanted the cool sound. keep the edge gauge and custom tune it thats a good way to save some money you can get the x3 sct and run your edge gauges. thats what i did. and as far asthe exhaust goes if you like the sound of jet engines when your sittin still and a nice loud tone when your on it straight pipe it. if you want it cleaned up a little and not so loud under load put a little muffler. those are the cheap options for fun after that studs egr delete and a torque convertor
you can keep the edge for the gauges.. just keep it at 0.... for the custom tunes go with something like this: SCT X3 Custom Innovative Diesel Tunning
no need for an intake... and for exhaust a budget minded 4" TB MBRP... we can give you a package deal setup that will save you some money... -Raul |
I would go SCT and like said above keep the EDGE and use them as gauges if on a budget, we have 4" Straight Pipe's starting at $249.99 for a full turbo-back system and Stainless 4" TBE for $306. Intakes on a 6.0 is not a necessity unless sound is a big thing, the factory system filters and flows extremely well!
Diamond Eye 03-07 Ford 6.0L Powerstroke 4" Turbo Back Single Exhaust |
