Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
Old 05-28-2007, 06:01 PM
gimmefuel gimmefuel is offline
sct excalibrator 2 question
Just ordered my first mod for my 06 F350 and after reading the sct website it says the excalibrator ships "blank" I purchased it through the rpm outlet online and was under the assumption the unit came preprogrammed. Am I wrong ? thanks for what may seem to be a stupid question
Old 05-28-2007, 06:07 PM
Logan Logan is offline
The Fat Mod
I am not sure about the RPM outlet. But, if you order one through LIPD, DJs or Innovative, once you get the tuner, they send you the tunes once they get the PCM codes or codes off of the SCT once you hook it up to the OBDII port. You will also need some gauges with that ASAP.
And to the ORG.
Old 05-28-2007, 06:12 PM
Thanks for the info appreciate it.
Old 05-28-2007, 06:33 PM
The Fat Mod
Anytime. If you need anything else, let us know.
Old 05-28-2007, 07:07 PM
ABOBB ABOBB is offline
Is it even worth it???
Welcome to Powerstroke.org
You need to get some kind of gauges to go with that SCT... It's not good to add a tuner, or chip, and not be able to monitor critical enigine parameters.
Old 05-29-2007, 02:41 AM
Keith T Keith T is offline
It is shipped "blank" because you need to read the strategies from the PCM. Then dealer will either email you, or yyou can mail the unit back and then have custom tunes installed for your truck. The SCT I got from Innovative has custom tune for my truck. Keith
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
