So, since I'm gonna be doing studs and gaskets... - Ford Powerstroke Diesel Forum
Old 07-13-2010, 10:27 PM
Chapter Director
Send a message via AIM to Fantom
Whether I need gaskets or not, I'm gonna be doing studs and a set of black onyx gaskets, can't delete the EGR (stinking california) I'm gonna go with a bulletproof EGR cooler and rebuild the oil cooler and replace the screen on the HPOP. The turbo drain tube was already done from ford back in '08. Also going to add a coolant filter and flush the system. So what else needs to be done or should be done while the truck is apart? Anything more I should do since I plan on fuel and turbo upgrades in the future?
Head Studs / Head Gaskets
Upgrade EGR Cooler
Rebuild Oil Cooler
Replace HPOP Screen
Flush system
Coolant Filter
Drain Tube is done
Old 07-13-2010, 11:59 PM
Looks like you got everything....at least everything I could think of.
Old 07-14-2010, 12:01 AM
Chapter Director
I think I need to add something to make it smoke. Like huge clouds of smoke, even when the truck isn't running.
Old 07-14-2010, 12:57 AM
set of injector would be nice!
Old 07-14-2010, 01:56 AM
When I did mine I also did the Elites head coolant lines.
www.elitedieselengineering.com - 6.0L Coolant Circulation Line Kit
Old 07-14-2010, 07:53 AM
Chapter Director
HAHAHA, they sure would. But that'll have to be later
This may be going on the list, thanks
Old 07-14-2010, 08:56 AM
Lt. Negativity
I wouldnt. But thats me, and a discussion with a few bigger folks why we dont do those.
Fantom
Check the Heads, deck them, Id also flush them as well while your at it. Check your LPOP Gear Set. Just make sure it looks good.
Intake manifold have that flushed as well or cleaned out.
Id go ahead and do the regulated return but thats me since your gonna have it apart.
Check your water pump make sure it looks good.
All I can think of right now.
Old 07-14-2010, 03:16 PM
whos doing the work?
Old 07-14-2010, 03:19 PM
Chapter Director
Sure as hell ain't gonna be me
Not sure yet, I'm gonna talk to the owner of Elm Ford and see what kind of deal he'll make me. We just did some asphalt work for them a couple months ago. If not, a local diesel shop.
I see you're in Sutter, you know of anybody?
Old 07-14-2010, 03:31 PM
i just got done with mine and we have a couple of other 6.0s lined up for studs. i just work out of my shop at my house whenever we arent paving lol. just make sure if you have ford do the work that you get your heads machined flat like kevin said.
