CTS Insight - Ford Powerstroke Diesel Forum
Old 07-07-2010, 10:58 AM
CTS Insight
Hey all, I just finished my install of my CTS Insight, and it is a pretty good little machine. The only problem I have with it is that the '03 6.0 does not have many capablitlies through the OBDII or that's what Edge told me. Here are some pictures, and if anyone has a 2003 6.0 with an insight I would like to know what gauges you are running through it. I would also like to thank Adam at FCDP, he has been awesome. Thank you in advance!
Old 07-07-2010, 11:01 AM
Unapologetically American
Feedback Score: 4 reviews
That looks badazz Kenny! Did you have to drill a huge hole for the cables? I just ordered mine
I thought you might pic that background
Old 07-07-2010, 11:18 AM
Ya, I love the USA!!! But as far as drilling, the only thing I needed to drill was the plastic plate coming from the engine compartment to the cab. Other than that it was a breeze. I saw you ordered yours, that is going to be awesome in your truck.
Old 07-07-2010, 11:34 AM
I plan to use the same background . Thanks, I hope that it will
How long did it take to install? Did you have your manifold already drilled for the EGT probe?
Old 07-07-2010, 11:48 AM
I didn't have it drilled/tapped before, but that took me about an hour. But the wires, and inside install only took about 45 minutes, but I was taking it pretty slow texting Jeffrey and all.
Old 07-07-2010, 11:52 AM
Cool, mines already drilled, tapped and has the bung threaded in . Jeffrey can be annoying when you're working on a vehicle
Old 07-07-2010, 04:17 PM
Do you know what PIDs aren't available for '03 6.0's. Are the '03 & '04's essentially the same (same PCM?)? I just rec'd my CTS Insight, but haven't installed yet...truck is in the shop due to bad injector and haven't had a chance to try it out yet.
Old 07-07-2010, 04:59 PM
I'm curious what you aren't able to see with the Insight on your 03 too Kenneth?
Old 07-07-2010, 05:02 PM
I have an early 04 and have a lot less options to watch than I expected as well.
No trans temp
No engine oil temp
No voltage output
No boost.
It doesn't read my vin number either. I even put it back to factory tune with the sct to see if that would make a difference and it didn't.
I sent them an email asking what all I should be able to see. If this is all I get, I'll be sending it back.
Old 07-07-2010, 05:05 PM
No trans temp
No engine oil temp
No voltage output
No boost.
I'd send it back too! I really bought mine for monitoring the ECT and EOT delta
You guys are better off with a 4 gauge pod. Trans, boost, ECT and EOT, and then one more for EGT's
