My father uses Amsoil in our 7.3 and swears by it!
As far as the Mercon SP. Do not use Mercon III, IV or V. It has to be the SP. The only place I have been able to find any is at the dealer.
I believe that Amsoil does make a synthetic that is made to meet the requirements and specs for the SP. I don't know for sure. |
Synthetic Universal Automatic Transmission Fluid (ATF)
APPLICATIONS AMSOIL Synthetic Universal Automatic Transmission Fluid is completely compatible with other synthetic and petroleum automatic transmission fluids. AMSOIL ATF is a universal, multi-functional fluid that greatly reduces the need for specialized fluid inventories and the possibilities of misapplication. AMSOIL ATF is recommended for transmission, hydraulic and other applications requiring any of the following specifications: * GM DEXRON® II, III & VI * Ford MERCON®, MERCON® V & SP * Chrysler ATF+ through ATF+4® * Honda Z-1 (Not for use in CVT transmissions) * Toyota Type T and T-IV * Mitsubishi/Hyundai Diamond SP II & III * Allison C-3, C-4 * Caterpillar TO-2 * Voith G607, G1363 * ZF TE-ML 14A, 14B, 14C * Mercedes Benz 236.1, 236.2, 236.6, 236.7, 236.9 * BMW 7045E * NAG 1 & 2 * JWS 3309 * LT 71141 (ESSO) * Nissan Matic D, J & K * Vickers I-286S & M-2950S AMSOIL - Synthetic Universal Automatic Transmission Fluid |
I'm glad to hear that Amsoil has an approved ATF fluid! I think I've decided to go with Royal Purple oil & gear lube and Amsoil ATF. I found a pretty cool "independant test" that North Carolina University did comparing the fuel and emmissions of Royal Purple motor oil vs Amsoil and Havoline "mineral" oil. RP outperformed both in all tests. You can download the report from RP's website. Anyone know of any other tests that show different results?
Thanks! |
I am currently running the Valvoline Premium Blue Extreme 5w-40 full syntactic..its super expensive but I am going to double my oil change intervals.
I have put about 4K on the Valvoline and I love it..seems to smooth the motor out. ![]() I ordered analysis test for the oil..so when I change it..I will get it tested.. |
Schaeffer Oil makes some of the finest syn products around(better than Amsoil or Royal Purple). Lots of big trucking firms use it and they have extended drain intervals. If you just simply decide to use a syn product and just double your drain milage any problems motor could be drawn to that(without proper testing). Typically the company spells out that you can run said oil for X number of miles depending upon driving habits and regular oil samples. Schaeffer has there own lab where youi can send your stuff for analysis an thus find an approatte drain interval sutiable to your driving habits.
I just did the Amsoil with the twin bypass filters seems good, I'm doing my tranny with the Amsoils ATF next week, there is a guy in so cal who can change it all out including the TQ. He uses compressed air to blow all of the old ATF out. The oil and dual filter set up was around 500. But I use Royal Purple in my Jeep transfer case and tranny and made big difference. So I guess I was no help to you... my friend used Amsoil on his 7.3 and it now has 450K on it.
We test all of our oils as well. We use Blackstone Laboratories. The kit is free and the report is like 22 bucks I think.
Blackstone Laboratories We usually start out at 8k miles, send in a sample, and see what they say. They will recommend the next sample interval. Remember new vehicles show crap in the oil from break-in. I would never just jump up intervals without a lab telling me its ok. |
SP ?? I know Amsoil was going to be the first aftermarket company to provide SP ATF , But I can not confirm if it is being distributed as of yet...?
Check Amsoil and see if their new SP replacement is on the market yet.. last I heard it was still in development, But rest assured when it (Amsoil SP) comes out it will be the best alternative. SP is SP 4 a reason , do not substitue anything 4 Mercon SP until you are Proof + that it is exactly werd 4 werd an SP equivalent. Just my
bypass filter
