6.0 shift kit? - Ford Powerstroke Diesel Forum
Old 05-07-2010, 05:36 AM
6.0 shift kit?
Does anyone know if there is a shift kit available for an 04 F350 CCLB DRW 6.0? Any help would be appreciated.
Old 05-07-2010, 05:37 AM
no there is not the 5r110 is a fully electronicly controled trans you just need a sct programmer and custom tunes
Old 05-07-2010, 07:13 AM
You can get a modified direct solenoid that will help a lot. Check Gogodiesel.
Old 05-07-2010, 07:25 AM
Almostdunfukinwidit
Yup just make sure your tunes are adjusted for it. Otherwise its gonna shift hard as hell
Old 05-07-2010, 08:49 PM
Send a message via Yahoo to Lubbockguy1979
They make a shift kit. It is to address a problem in the case. It does not have a performance gain just keeps the tranny from gernading on 03-04 trucks. The direct solenoid is a great adition. Custom tuning though is the best option.
Old 05-08-2010, 08:54 AM
Lt. Negativity
What shift kit do you speak of ? My 03 has yet to grenade and Im no where near stock from the motor back to the suspenion Im still on a stock tranny since 20k im at 105k Tuned and performance since. Only thing I know of is the Direct Selnoid.
Old 05-08-2010, 09:14 AM
SK® 5R110W
5R110W Ford Torqshift
2003-2005 Vans, Trucks, SUVs – Gas & Diesel
Reduces/Corrects/Prevents: Goes to Neutral while driving or stopped, Won’t move forward or reverse, Slips in reverse, Blown rear case lugs
this is the description given. there is a tsb that addresses this from ford for early 2003 trucks. guess you have been luck, the time is ticking or ford corrected the issue... take your pick
Old 05-08-2010, 10:47 AM
NOT a Democrat
I did that before with my Crown Vic. I rebuilt the trans and did the "Jerry Mod". Forgot about it and loaded a tune. It was AWESOME but wouldnt have lasted long. Simply had the tuner readjust his trans tune.
If you are looking for performance shifts, I would build it through tuning.
Old 05-09-2010, 07:38 PM
This is the only correction kit I know of.... Made by TRANS-GO / Gill Younger I swear by trans-go correction kits.....
SK® 5R110W
Old 05-10-2010, 06:47 PM
The correction kit is reffered to as a shift kit on every tranny site I've seen. On the subject the 03-04 trannys could use a lot of the updated hard parts from the 05+ trannys. There have been a lot of updates since 04.
