twin turbo setup - Ford Powerstroke Diesel Forum
Old 05-05-2010, 08:01 PM
Send a message via AIM to BLKF250
twin turbo setup
Iam interested in doing a twin turbo set up on my truck in order to create a good amount of power iam looking at innvotation diesel twin turbo setup 700HP or 1000HP....in order to run a setup like that what all needs to be done? As far as oil and fuel filter housing deleted or remove, do they supply you with the kit or you gotta buy a sepreate one? Does the crank or cam or anything like that need to be swap out with something bigger or stronger? Also what about the heads are they going to have to be done to handle the psi and the transmission going to need work to keep up with the power? and advice is welcome thanks
Old 05-05-2010, 08:05 PM
I've read that any boost over 50psi, heads will have to be done. Lack of fuel is going to keep you from getting numbers that high.
Tranny, heck. You'll need a built tranny for sure..
Old 05-05-2010, 08:45 PM
Lt. Negativity
Look at spending over 16k total, I had this all planned out before.
6k for Turbos,
3k for injectors
4k transmission
1k fuel system stuff
2k Motor work and updates (machining etc)
3k labor for install and removal
Thats just an idea of things your getting into, and doesnt mean that they dont find anything wrong inside your motor.
Old 05-05-2010, 09:43 PM
Another 6Slow
i bet youll be way north of 20 grand before it can put down those kind of numbers reliably but thats just my .02
Old 05-05-2010, 09:44 PM
eek 16k on top of the already 48k i have spent on the truck, sounds like fun but dont think im game to spend another 16k. maybe one day
Old 05-05-2010, 10:01 PM
Lt. Negativity
Oh another thing if you aint got the money to play I wouldnt advise doing anything more.
Old 05-06-2010, 04:18 AM
Feedback Score: 5 reviews
the next steps for power on our trucks are the expensive one, gotta have deep pockets.
Old 05-06-2010, 06:27 AM
Deep pockets for sure! Don't forget about Trusted Performance. They are great guys to work with and have everything you need to put compounds on your truck, including the oil/fuel filter relocation.
-French
Old 05-06-2010, 06:50 AM
wow! was thinking of something like the first guy but I think i will just stick with what I have lol
Old 05-06-2010, 05:39 PM
Send a message via Yahoo to Lubbockguy1979
the cheapest way to mod your truck into to a twin turbo is to take it to the dealer bend over and take what they give you. up your payment a lot and pick the color of your new 2008-2010 6.4.
