What axle do I have? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-04-2010, 03:14 AM Thread Starter
MCox32's Avatar
I have an 05 f350 srw. I called the dealer and gave them my vin and they said they couldnt tell me what axle I had, I thought the vin told everthing on that truck. I looked on the rear end and I could make out a F81A WW but dont know if thats what they would need or not.
MCox32 is offline
post #2 of 12 Old 05-04-2010, 04:18 AM
cpayne6335's Avatar
on the drivers side, there is a sticker with tire info on it. On the bottom, you will see something about a axle code, that is what ford needs.
Looking for a FORD.
Chris
US Army, MOS:88M Ft. Lewis 17th Fires
cpayne6335 is offline
post #3 of 12 Old 05-04-2010, 05:49 AM
Abrannan19's Avatar
Feedback Score: 5 reviews
what are you wanting to know? You truck should have a Dana60 rear end with 3.73 gears
Adam Brannan
First Coast Diesel Performance
Abrannan19 is offline
post #4 of 12 Old 05-04-2010, 11:01 AM Thread Starter
MCox32's Avatar
I was wanting to get 430s for it because i have 38s on it now. Would that be a good gear for it? I dont pull anything much mostly just riding around.
MCox32 is offline
post #5 of 12 Old 05-04-2010, 03:35 PM Thread Starter
MCox32's Avatar
I have some #s off of it would it look something like 4U5A-1532-AA? Then on the data tag thing on the door under axle it says 3L?
MCox32 is offline
post #6 of 12 Old 05-04-2010, 07:05 PM
Abrannan19's Avatar
4.10's would probably work fine and you can get ford parts..they are pricey but they work well.
Adam Brannan
post #7 of 12 Old 05-04-2010, 07:09 PM
justinbaldwin69's Avatar
dana 60 up front,sterling 10.5 in rear
anything but a chrysler product
the only thing that runs good on a dodge is the drivers mouth
dodge boys
FORD MEN
justinbaldwin69 is offline
post #8 of 12 Old 05-04-2010, 07:17 PM
im guessing thats the same for my 02' f250?
19558077 is offline
post #9 of 12 Old 05-04-2010, 07:30 PM
some of the early superdutys came with dana 50 up front also,mine is an 03 and it has the 60,check the numbers on the front dif tag.
dodge boys
FORD MEN
post #10 of 12 Old 05-05-2010, 03:10 AM Thread Starter
MCox32's Avatar
so i need to different types of gears? dana gears in front and ford in the rear?
MCox32 is offline
