Thought with an SCT I could.... - Ford Powerstroke Diesel Forum
Old 05-03-2010, 08:08 AM
Air Assault!!
Send a message via AIM to MPTonyT
Monitor my EOT and ECT? I was about to see ECT (190F) but was not about to see EOT. Now i also chose to monitor the Trans Temp and it said invalid.... Now this was as i was running down the road and my wife had the SCT in her hand playing with it. question is.... shouldn't i be able to monitor both ECT and EOT?
Old 05-03-2010, 09:56 AM
Do you have the x3?
Old 05-03-2010, 10:41 AM
Air Assault!!
I have the SF3 but says X3 on the sticker. Funny cause the Guy at SCT said they were the same. Only difference was the canned tunes.... which mine has.
Old 05-03-2010, 10:44 AM
I will have to check. I cant remember if I could read both of those parameters or not.
Old 05-03-2010, 10:58 AM
Slacker
Feedback Score: 4 reviews
Yeah, you should be able to read both using the data logging software.
Old 05-03-2010, 11:15 AM
Air Assault!!
I went into the Display setup and selected the ECT and Boost but EOT wasn't there. maybe ill call SCT if others are able too. Does 190 sound about right?
Old 05-03-2010, 04:30 PM
190 sounds about right, that's what mine run in the city. Haven't really been on the highway. I run a Edge Evolution only for gauges.
ECT and EOT should be roughly almost the same temp. 5 degrees is the most difference I have seen once everything is up to running temp. I have seen on the forum that if these 2 temps get farther apart than 14 degrees your cooler is on the way out!!!
Didin't know that, so I have mine set to watch these 2 temps all the time!!!
Old 05-03-2010, 05:39 PM
I have the x3 and mine doesn't have oil temp either just ect
Old 05-03-2010, 05:59 PM
Slacker
Yes, both are available.
Old 05-04-2010, 05:31 AM
Air Assault!!
So i asked JR the same questions i asked here and heres what he said....
The parameters that are preloaded to these devices are generic and should apply to most vehicles, but if you want to look at a full list of parameters specific to your vehicle you may want to install Livelink to a laptop and use that to datalog.
SCT Automotive Performance Products
http://www.sctflash.com/support/inde...8&pcid=0&nav=0
Hope this helps others with this question.
