Wiring - Ford Powerstroke Diesel Forum
Old 04-28-2010, 10:42 PM
Exclamation Wiring
I'm not sure if this is the right section. But I'm kinda in a bind. I am trying to hook up my gauge and the kit came with a power wire with the constant 12, ignition 12, ground, and illumination in a weak 1 foot strand. Is there somewhere I can tap into behind the instrument cluster (possibly the light switch) that would power this? If so, can anyone let me know which wires to use so that I'm not shorting anything out. Thanks.
PS: Kinda need the info asap please.
Old 04-28-2010, 10:57 PM
back to business
I got 12V ign switched and dimmer from behind the head light switch. I ran ground to the ground bolts by the under dash fuse box.
Sorry, I don't remember which wires I used. I used a multi meter to find the right ones. I'm thinking one of them was lt blue/red, the other may have been brown/??.
Old 04-28-2010, 11:06 PM
Do you remember which wire was for what?
Old 04-28-2010, 11:12 PM
back to business
I THINK that the lt blue/red was ign switched 12V. The other would have been dimmer.
I'd double check it before you go splicing into anything though. I was a while ago and I've been into a few beers this evening.
Old 04-28-2010, 11:16 PM
Thanks man. I really appreciate it. I'm going to see what I can do with it. First chance I get, I'll let you know how it went.
Old 04-29-2010, 12:24 AM
ARMY MOM!!!!
Send a message via Yahoo to korg70kbc
yep
Old 04-30-2010, 05:33 PM
I did mine a couple of weeks ago, I will pull the switch out tomorrow and get a pic and post it up if you want???
