Crank Case Ventilation - Ford Powerstroke Diesel Forum
Old 04-28-2010, 01:05 PM
when ever i re-route my ccv hose is it would it be a good idea to cut a hole and weld a nipple onto my exhaust pipe at an angle toward the outlet and route it like that so i wont have to worry about it dripping oil?
Old 04-28-2010, 01:14 PM
that is going to smell... why not just purcahse a CCV kit that routes the oil to a canister that you drain every couple of months?
-Raul
From what ive read on several threads, nope! It will cause a presure change and turn your truck into an oil fountain. Just do a real kit like Raul@StealtAutomotive sells. Thats the only one that would be worth running on a vehicle in my opinion.
Old 04-28-2010, 01:15 PM
Raul beat me too it!
I would think that would cause the truck to smoke when the oil running down the inside of the exhaust pipe would get hot from the exhaust gasses. That's just my opinion.
Old 04-28-2010, 01:34 PM
shaking things up
if you put it close enough to the downpipe i think that it would burn off
Old 04-28-2010, 01:42 PM
Powerstroke Junkie
It will burn it off, the problem is if it isn't placed at exactly the right angle in the right location you will cause negative pressure and turn your powerstroke into a oil fountain, just isn't worth the risk as it is slim you would get it right the first, or tenth time around. Use the kit that Raul sells.
CCV Mod
Old 05-05-2010, 01:03 PM
ok thanks alot
