Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
Old 05-02-2007, 06:32 AM
huhner5 huhner5 is offline
Settings on Xcal 2
For you guys out there running an Xcal2.. I just got mine from DJs and am just looking for some info to set shift points, Rev Limiter etc.... Just don want to hurt anythin and lookin for a good set up..
Old 05-02-2007, 09:17 PM
stump0331 stump0331 is offline
KILLEMALLLETGODSORTEMOUT
Tournaments Won: 1
the only setting i messed with in the box is the speed limiter which i turned off.
the tuner should be able to set everything else up
Old 05-03-2007, 04:57 AM
xtremexj xtremexj is offline
Ditto. DJ has spent a lot of time adjusting the shift points to match the engine programming and it is bang on. The only thing that I did was adjusted for tire size and the shifts are amazing.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
