Gauge wiring on 05 F250 6.0 - Ford Powerstroke Diesel Forum
Old 04-24-2010, 11:18 AM
I ve got my gauges installed, but was wiring them up and the diesel manor instructions say to wire the switch'd ignition to a red/yellow trace so I did. But now they are only working when the lights are on all the way.
Essentially I have the constant wired to the battery, the switched power is to the red/yellow trace, and then the ground.
Anyone with an 05 have their gauges wired to a different switched ignition wire? I tried all the wires next to this one on the same plug and none of them worked right. Its a gray plug with like 6 wires.
Thanks.
Old 04-24-2010, 11:26 AM
Mine are wired from the switched ignition off the radio
Old 04-24-2010, 01:16 PM
Can you tell me what color wire that all was? That would be ideal. I have and will pull my dash again if i have to, but I just did for my sirius too lol.
THanks man.
Old 04-25-2010, 10:29 AM
A DVM or even a 12v test light is your friend here. There are lots of switched sources you can use. I tie my lights to the dimmer switch so they dim with the dash lights.
