What else do I need to do for performance?
Ok, i know this is the same old question, but im at a stopping point. i have no idea what else to do. everything is list in my sig. Im happy where it is, but i might be missing something.. any ideas? (im not looking to redo the entire motor) just maybe a few bolt on's that might help!
how much money do you have? maybe get a set of 155's.
yea ive started looking into them... there is a set on here for sale.. i think 1200? or 1000 with good cores. would that help alot?
I don't see anything about getting rid of the EGR in there.. I HIGHLY suggest either completely deleting it or blocking it off at least.. Especially if you're running hot tunes
not alot but you will notice the extra power. if you did that i would get an airdog or a fass fuel syestem too. i jut depends how far down the rabbit hole you want to go! lol
You missed:
Injectors, turbo, studs, EGR delete, and CCV re-locate...maybe a fuel system, coolant filter...gauges... |
i was going to try to do the egr if the heads go... some say that as soon as you delete the heads go next... i might look into that... im happy with my 03 turbo extendedm power... im happy the way it is. just looking for some stuff i missed. ccv does nothing for me or the coolant filter. no performance gains out of it... thanks though.. 155's might be the trick!
coolant filter and oil bypass are very good things for this motor. preventive maintenance. egr delete is also preventative.
Eeerrrrr.. The heads don't go after an EGR delete... lol. EGR delete is to keep the head gaskets from blowing.
Usually what happens is that an EGR delete is added AFTER the heads blow because ppl thought they had "The one"... lol |
sounds good... ill do the egr delete... and look into the 155's a friend of mine did the coolant filter. i guess i can do that... looks pretty inexpensive to do.. thanks for the help!!
