gauges ?
i have a egt and trany gauge i have a 07 and use the stock boost gauge . i wanna get one more whats some good things to monator?
Fuel pressure, oil temp, coolant temp
volt would be another one i would want
out of those 3 witch one would you do bud?
Well I would probably go with fuel pressure. When you have oil or coolant temp you usually want both of them so you can watch to see if they are not more than ten degrees apart. Voltage would be good to, but just personaly I would ho with fuel pressure
if i had no budget in mind... i would do fuel pressure.... or coolant which is water temp....
not trying to be stupid but whats the volt monator and do? what is it
ok volts or oil temp? whats is the max oil temp i need to look for? towing or whatever?
